Does anyone have this setup
i was wondering if anyone has:
-b16a or b crank
-early 90s prelude b21 rods
I was wondering because i think this may be the combo that gives the highest rod stroke ratio on oem b series parts. It calculates to like 1.8 something which is pretty high. I guess with this you would have to rev pretty high.
-b16a or b crank
I'd do some research as to deck height on a setup like that. You'd definately need custom pistons, but even so, I believe you'd be wacking the head on a B16A block. The B16B uses the P72 block like the GSR and ITR so it is indeed a possibility. I'd still be iffy about it until you can break down both blocks and get some measurements.
