FAQ.... EK & Bseries swap (2 or 3 99si mounts)?
this is a 96 civic ex.
94 LS motor
I know i can use all mounts from the integra but I which do i need?
*99si rear tranny mount #50827-s04-n10 $29
*99si driver side bracket
*99si driver side BLOCK mount
<FONT COLOR="blue"> BTW what PS unit to i have to get to keep PS in my EK? </FONT>
94 LS motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApexiChild »</TD></TR><TR><TD CLASS="quote">this is a 96 civic ex.
94 LS motor
<FONT COLOR="blue"> BTW what PS unit to i have to get to keep PS in my EK? </FONT> </TD></TR></TABLE>
As mentioned already, you'll need two mounts from the Si, the rear tranny mount with the part # you have listed and the driver's side upper engine mount bracket(Honda P/N 11910-P30-000).
To keep PS in your "EK" you'll need the Integra pump and bracket. Your "EK" power steering line and return hose will connect to it without a hassle.
94 LS motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">i am going to do the same thing, do i need vibration mounts too?</TD></TR></TABLE>
Vibration mounts? Are you referring to polyurethane motor mount inserts? The only thing that I would really recommend is replacing the liquid filled driver's side mount with the HCP Engineering solid mount. I have it and have yet to experience wheel hop with it installed. Otherwise, I have found the rest of the OEM mounts to be more than sufficient.
so, im doing this swap this week, what pass. side mount do i use (96 ls into 96 civic) just want to clear this up... so far i need a
99 SI driver side bracket
99 SI rear mount
Passenger mount??????????
please help me out..
thanks
99 SI rear mount
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99crx01 »</TD></TR><TR><TD CLASS="quote">so, im doing this swap this week, what pass. side mount do i use (96 ls into 96 civic) just want to clear this up... so far i need a
99 SI rear mount
thanks</TD></TR></TABLE>
I can't gurantee this part for sure since you're swapping a B18B, but you should be able to use your stock Civic passenger side mount for your swap just like I did with my JDM B18C swap.
99 SI rear mount
asocallocal
Apr 11, 2008 10:28 PM
SyDuck
Jan 28, 2005 06:59 PM
