Is this catch can setup possible?? (pic inside)
Old Oct 8, 2004 | 04:04 AM
hovic's Avatar
Default Is this catch can setup possible?? (pic inside)
Hi guys...
can you please check out my catch can setup.. Is it possible to install the cans as shown in my pic??? Sorry for the very bad graph :-) I did that in 2 minutes
C1-C3 are the cans
IM is intake manifold
Old Oct 8, 2004 | 09:33 AM
Steve91's Avatar
Default Re: Is this catch can setup possible?? (hovic)
Yes, but you can do it much simpler. You only need one catch can. I run a Moroso breather can. The block breather an the valve cover breather go into the Moroso. From the bottom of the Moroso breather, I have a -10 line running to a fitting on my Moroso Pan. The top of the Breather has a K&N filter to vent
Old Oct 8, 2004 | 10:07 AM
hovic's Avatar
Default Re: Is this catch can setup possible?? (Steve91)
Thanx for reply.. The problem is that I have 2 lines coming from the valve cover So I´ll need a second can if I would go with a moroso can right??
Old Oct 8, 2004 | 01:04 PM
Steve91's Avatar
You can just use a T fitting to merge the lines together. You don't need to mess with more than 1 can. One is plenty.
http://www.moroso.com/catalog/...13400
Old Oct 8, 2004 | 01:26 PM
hovic's Avatar
ok thanx for the infos.. last question.. I´ve got already a greddy oil catch can without a breather so I´ll use a T fitting to connect all libes to the can but where´s the best place to connect the catch can to.. To the itake manifold or Intake pipe? I´ve got a turbo system and I´ve no idea where to connect the line coming from the catch can to.. (the green one shown in my graph)
dE.fUsEd
Nov 17, 2011 02:13 PM
bart2546
Jan 12, 2007 02:02 PM
DannyDeuce
Sep 8, 2006 03:46 PM
AntiStock
Dec 26, 2005 04:10 PM
Propulsion
Nov 24, 2003 03:55 PM
