b18 swap question
Old Oct 7, 2004 | 04:30 PM
matto2413's Avatar
Default b18 swap question
did a b18 motor swap but not sure if it came with the distributor or if the stock LS distributor is in it. Is there a way to tell,and also will the VTEC work with the stock distributor, or do you need a GSR one?
Old Oct 7, 2004 | 04:45 PM
LSvtec03's Avatar
Default Re: b18 swap question (matto2413)
if they used the LS distributor, it will work, but they will have cut off one of the lobes where it bolts to the head. this does not affect vtec.
Old Oct 7, 2004 | 05:03 PM
ApexOne's Avatar
The dist. is not in the motor, it is aside the head just to the left of the valve cover when your looking at the motor from the front of the car. It is the black metal and plastic thing that all your sparkplug wires connect to. Any dist. will work as long as it is from another b-series motor.
jeremyrocksursox
22
Apr 3, 2010 03:09 PM
StoopidChris23
Feb 16, 2010 12:11 PM
Dutch-VTEC
Mar 25, 2006 08:05 PM
mdj_ge
Jun 22, 2005 06:08 PM
streetlvlhatch
Apr 11, 2004 06:45 PM
