WHY DOESN'T MY VTEC WORK??
Old Oct 3, 2004 | 11:44 AM
Fern95GS-R's Avatar
Default WHY DOESN'T MY VTEC WORK??
i have a 95 gs-r and my vtec doesnt work ? i try to red line it but it wont let me. i hear the vtec kick in at 7000 rpms but it only goes to 7200 and then it stops and i cant go any farther ?? how do i make it work with out me having to buy something or do i HAVE to buy something ?
Old Oct 3, 2004 | 11:57 AM
AlxSiR7's Avatar
Default Re: WHY DOESN'T MY VTEC WORK?? (Fern95GS-R)
did you wait for your car to warm up??
Old Oct 3, 2004 | 12:02 PM
garados's Avatar
how's your oil level?
Old Oct 3, 2004 | 12:16 PM
untitledsn41's Avatar
do you have a check engine light?
Old Oct 3, 2004 | 12:24 PM
T3mp3sT's Avatar
Default Re: (untitledsn41)
check oil levels too. if the pressure isn't significant, vtec will hate u
Old Oct 3, 2004 | 12:30 PM
Dc2 Powered's Avatar
gsr vtec kicks at 4400. secondary butterflys open at arounf 5750 which is what u heard but yea check your oil pressures
Old Oct 3, 2004 | 12:33 PM
SiRb16's Avatar
Default Re: (T3mp3sT)
i would advise you to check the oil pressure as well, i had a similar problem 2 weeks ago, oil pump stopped working and that led to me having to change the main bearings and well as the rod bearings i should get back my integra SiR tmrw but my mechanic has advised me cause of the rebuild ill have to do some early shifting to break the engine back in...Also u guys wondering integra SiR?...yea i live in jamaica, we get the good stuff here...JDM Honda Integra SiR, ill post pics wen i get the car back
Old Oct 3, 2004 | 12:55 PM
AlxSiR7's Avatar
Default Re: (jdmsirvtec)
um..yea, i got an SiR too...
Old Oct 3, 2004 | 02:57 PM
Fern95GS-R's Avatar
Default Re: WHY DOESN'T MY VTEC WORK?? (garados)
How would I be able to measure my oil pressure. AfterMarket Pressure gauge? Do you think an oil change will help? And I just bought it about 3 weeks ago from a small dealership....with 94k miles on it. Now would the car run normally right now even with bad oil pressure? Becuz my car runs fine but I dont feel the power I think I should from a V-Tec..
Old Oct 3, 2004 | 05:12 PM
are you throwin any CELs?
is your oil at the fill line on the dip stick?
do you wait for your car to warm up?
Old Oct 3, 2004 | 05:20 PM
wlee2's Avatar
Default Re: WHY DOESN'T MY VTEC WORK?? (untitledsn41)
How do you even tell if vtec is active? coz mine doesnt make any noise, i have heard though that vtec doesnt work when the engine is cold
Old Oct 4, 2004 | 12:10 AM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitledsn41 &raquo;</TD></TR><TR><TD CLASS="quote">are you throwin any CELs?
what is CELs again..?
may be u got a smooth transition...my 97 gsr vtec kicked very smooth...with modified instake and header + exhuast piping i can barely tell the vtec at 4400, + 5400 then the rpm hand is like having boost.....well i can tell by the sound but very smooth transition
Old Oct 4, 2004 | 06:17 AM
BlackOnBlackTeggie's Avatar
Default Re: WHY DOESN'T MY VTEC WORK?? (yeegsr)
if u have a 97 gsr the butterflys open at 4400 and vtec is at 5800
Old Oct 4, 2004 | 06:28 AM
wrong, stop giving false info
if you have a gsr
vtec kicks in at 4400 and secondarybutterflys not a 2nd stage of vtec nothing like that opens at 5750
here let me make it more simple
4400 - Vtec
5750 (according to Helms) - Secondary Butterflies (NOT VTEC, not a second stage of VTEC, nothing like that)
Old Oct 4, 2004 | 02:23 PM
Fern95GS-R's Avatar
Default Re: (Dc2 Powered)
where can i go to check my oil presure??
Old Oct 5, 2004 | 01:04 AM
yeegsr's Avatar
Default Re: WHY DOESN'T MY VTEC WORK?? (BlackOnBlackTeg)
pretty dann close to what i see from rpm meter and the sound i heard....well 4400 and 5800 then...since ur is more accurrate persay
Old Oct 5, 2004 | 01:24 AM
JPRMOTOR.com's Avatar
Check oil pressure
Old Oct 5, 2004 | 04:30 AM
1gsr2envy's Avatar
Default Re: (JPRMOTOR.com)
check your computer cause my friend bought a 98 gsr from a dealership and it had an ls computer in it so it wasnt hitting vtec at all and it wouldnt reach red line
Old Oct 5, 2004 | 04:36 AM
K.F14's Avatar
Default Re: (1gsr2envy)
Check oil pressure and CELs.
Old Oct 5, 2004 | 04:41 AM
ki3t's Avatar
This user can set his title.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
CEL = Check engine lights....
As everyone else is saying ..... check oil pressure, let car warm, or check your CEL' s
AlxSiR7's Avatar
haha that sucks.. damn shady dealers
Old Oct 5, 2004 | 05:26 AM
Kimo's Avatar
Default Re: (AlxSiR7)
haha maybe they put an LS ecu in there and there is no vtec-
wouldnt the car bog really bad around 4400 if the vtec wasnt working? thats how it was on my old civic
Old Oct 6, 2004 | 05:43 AM
obd1 gsrs hit vtec at 4400 ,
0bd2gsrs hit at 5800
if not explain my 96 gsr with a skunk2 intake manifold( with no butterflys) hiting vtec at 5800
Old Oct 6, 2004 | 06:17 AM
furious94ls's Avatar
Default Re: (BlackOnBlackTeg)
Since your not getting a CEL, and I'm guessing your oil level is fine. Since you have posted after 10 people told you to check your oil, it leads me to believe you don't have a GSR. If the car cuts out at 7,000 RPMs thats the fuel cutoff. Where does your redline on the tach start?
Open your hood, the valve cover should say DOHC
VTEC
I say this because you purchased the car from a used lot. It may have started life as a 95 GSR, but was stolen and replaced with a LS engine and still have the GSR guage cluster. Or you just have an LS and think it's a GSR.
In order for VTEC to work
-Car must be at operating temp
-Throttle position
-Car must be in gear and in motion
-Oil level/pressure
There is one more and I'm forgetting it Someone help me out.
Old Oct 6, 2004 | 06:21 AM
cheezthis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackOnBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">obd1 gsrs hit vtec at 4400 ,
if not explain my 96 gsr with a skunk2 intake manifold( with no butterflys) hiting vtec at 5800</TD></TR></TABLE>
No, obd2 is no different than obd1 in terms of vtec and secondary rpms. I don't know why your car does that and would need more info on it to do so.
