engine swapped now idles funny
Old Oct 5, 2004 | 07:29 PM
luckecharm2004's Avatar
Default engine swapped now idles funny
ok i got my swap done and everything is fine..except...my sppedometer dont work and when the engine is idle it goes up and down.
this is a d 16 a 6 engine into a 88 crx dx...any hnits or anything would be apprecitaed
Old Oct 5, 2004 | 07:33 PM
dr_latino999's Avatar
Default Re: engine swapped now idles funny (luckecharm2004)
If your speedometer doesn't work then your VSS isn't working right. Make sure it is in all the way and even if it looks like it, give it a good push in. If the idle is going up and down, check your throttle cable, and also check your vacuum lines.
Old Oct 5, 2004 | 07:35 PM
Default Re: engine swapped now idles funny (dr_latino999)
what is vss? i am new to this..so u got to be barney style with me..lol
Old Oct 5, 2004 | 07:41 PM
LSVTEC 91 Civic's Avatar
Banned
Does your idle pulsate?
Old Oct 5, 2004 | 07:44 PM
Default Re: engine swapped now idles funny (LSVTEC 91 Civic)
yeah it goes from like 850 up to 1200 rpm every second
Old Oct 5, 2004 | 07:47 PM
Mr_CRX's Avatar
Might wanna clean out your IACV. It's on the back of your intake manifold. Two bolts hold it on, theres two coolant lines running to it, and an electronic plug. Take it off and blast it out with some carb cleaner. Most of them are usually all gunked up inside.
I've heard this can be a culprit of surging idles.
Old Oct 5, 2004 | 07:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckecharm2004 &raquo;</TD></TR><TR><TD CLASS="quote">what is vss? i am new to this..so u got to be barney style with me..lol</TD></TR></TABLE>
The VSS is the Vehicle Speed Sensor, you removed it in the swap and I am hoping you put it back in. It plugs into the tranny and has a long cable running from it to your speedo.
Modified by dr_latino999 at 5:13 AM 10/6/2004
Old Oct 5, 2004 | 08:06 PM
i will have to check that..i didnt do the swap i helped..i am new to working on cars...i specialize in car audio..lol can u tell me where this is located so i can check without having to go back to the guy who did the major work?
Old Oct 5, 2004 | 08:15 PM
I can only describe where it is so work with me since I am going off memory. If you pop the hod and look at the Intake manifold, you will look directly down and toward the rear crossmember and the tranny mount, you will hopefully see a cable that is plugged into your transmission.
Old Oct 5, 2004 | 08:24 PM
91civichatch2571's Avatar
you can see where the speedo cable goes into the tranny in this picture. http://www.binghamtonlife.com/...5.jpg
Old Oct 6, 2004 | 04:27 PM
ok i found the speedo cable it is connected to the tranny...bad news it is not connected to anything else. it was hanging under the car...so now do i need to repalce it and if so is it hard to replace?
Old Oct 6, 2004 | 04:30 PM
Well, if its not all beat up from being dragged under your car (had to laugh when i read that) it goes all the way up behind the dash and into the backside of your gauge clutster. Just pops in.
Old Oct 7, 2004 | 02:41 PM
Default Re: engine swapped now idles funny (91civichatch2571)
ok the speedo cable was shot..i bought a new one today and replaced it..it dont feel like the cable is connected in the tranny all the way...does it just pop in? i am unable to start the car right now cus of waiting on the throttle body....
noxon511
Jul 13, 2014 11:51 PM
TURBL0W
Feb 12, 2006 06:12 PM
KloC 95 EG
Jan 17, 2006 07:16 PM
egCoupe
10
Aug 12, 2005 12:54 PM
SjCiViCHB
Dec 1, 2001 01:45 AM
