Fluctuating idle
Old Feb 12, 2006 | 11:24 AM
TURBL0W's Avatar
Default Fluctuating idle
Ok i switched out the IACV already with 2 different ones. Nothing violent but still fluctuates from 1200-1500, also it doesn't do it all the time. One thing i noticed though is if its doing it and i stick my finger on the small hole in the TB it'll stop and idle becomes normal. what's the problem. All nipples are eithier connected to something or plugged up. Also no FITV, running itr throttle body/intake manifold.
Old Feb 12, 2006 | 11:46 AM
HandCommand's Avatar
Default Re: Fluctuating idle (lsvtec_power)
If you plugged that hole with your finger, the engine should have died. If it stayed running, you probably have a vacuum leak somewhere.
Check to see if anyone messed around with the idle screw. Ive seen many cars come into the shop with the idle screw backed out by the user trying to fix their idle problem, when it was something else like IACV or FITV, etc.
Old Feb 12, 2006 | 05:33 PM
TURBL0W's Avatar
Default Re: Fluctuating idle (HandCommand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandCommand &raquo;</TD></TR><TR><TD CLASS="quote">If you plugged that hole with your finger, the engine should have died. If it stayed running, you probably have a vacuum leak somewhere.
Check to see if anyone messed around with the idle screw. Ive seen many cars come into the shop with the idle screw backed out by the user trying to fix their idle problem, when it was something else like IACV or FITV, etc.</TD></TR></TABLE> i messed with the idle screw by screwing it all the way since the idle was too high. i'll check for vacuum leaks tonight. So if the idle screw is all the way in, will it expletive something up?
Old Feb 12, 2006 | 05:50 PM
86si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec_power &raquo;</TD></TR><TR><TD CLASS="quote"> i messed with the idle screw by screwing it all the way since the idle was too high. i'll check for vacuum leaks tonight. So if the idle screw is all the way in, will it expletive something up?</TD></TR></TABLE>
if its all the way in back it out 1 1/2 turns. it won't hurt anything anyway. but sounds like you have a vacum leak somewhere
Old Feb 12, 2006 | 06:12 PM
TURBL0W's Avatar
Default Re: Fluctuating idle (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">
if its all the way in back it out 1 1/2 turns. it won't hurt anything anyway. but sounds like you have a vacum leak somewhere</TD></TR></TABLE> yea but the idle is like 1500rpms high.where should i start with the vacuum leak? i'm running a hondata intake manifold gasket.
james007
Apr 30, 2010 04:26 PM
IntegraType-R
11
Jan 20, 2008 11:23 PM
eg6nes
Feb 21, 2005 03:57 PM
quik2kSi
Dec 27, 2003 09:04 AM
killa_lude
Aug 16, 2003 08:33 AM
