D16Y8 wiring
Old Sep 28, 2004 | 11:28 PM
hatchback_al's Avatar
Default Please look everyone!
I just bought a y8 and I'm an obd0 ef guy so im a little confused on something. This motor has an electrical plug wiht 3 wires, coming off the motor inbetween the oil pan and block. Can anyone tell me what this is and if its only used by obd2 ecus or does obd1 also use it. Thanks.
Here is a little pic to help u understand.
Old Sep 28, 2004 | 11:43 PM
lazynok's Avatar
i used a Z6 harness on my Y7 block (94 hatchback)... and i just didnt plug that harness into anything and my car runs fine
so its just an obd2 sensor you do not need. i guess its the crank position sensor but i dont know doesnt matter anyways
Old Sep 28, 2004 | 11:57 PM
Marauder's Avatar
Default Re: (lazynok)
Its a crank fluctuation sensor....for OBD2 ecu's
Old Sep 28, 2004 | 11:59 PM
=GAME='s Avatar
Default Re: Please look everyone! (hatchback_al)
lovely picture.
Old Sep 29, 2004 | 12:11 AM
Default Re: Please look everyone! (=GAMEOVER=)
thanks for the help guys, thats what i wanted to hear. Guess ill just hack it off Thanks for the props on the picture, i worked hard on it
Old Sep 29, 2004 | 12:28 AM
derspi's Avatar
I particularly dig the crazy gremlin demon.
Old Sep 29, 2004 | 12:46 AM
Default Re: Please look everyone! (derspi)
lol thanks
Old Sep 29, 2004 | 03:03 AM
murmur9's Avatar
You SURE he's not talking about the knock sensor on the back of the y8? Its right in that area too...
Sorry, just noticed that its by the crank shaft...my bad.
Old Sep 29, 2004 | 04:33 AM
spicoli's Avatar
hey why didn't my car come with a crazy demon
Old Sep 29, 2004 | 05:27 AM
jolt-tsp's Avatar
Default Re: Please look everyone! (spicoli)
Make the crazy gremlin demon your avatar!
Old Sep 29, 2004 | 06:54 AM
Slopoke's Avatar
Default Re: Please look everyone! (HTechBB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HTechBB &raquo;</TD></TR><TR><TD CLASS="quote">That plug is actually caled a Crank Position Sensor (very important).
It won't affect your performance but it needs to read info. to send back to your ECU.
Modified by HTechBB at 4:36 AM 9/29/2004</TD></TR></TABLE>
True, but if he's reusing his obd0 distributor and wiring, he wont need to worry about that sensor, because he has one in the distributor.
Old Sep 29, 2004 | 10:42 AM
Default Re: Please look everyone! (Slopoke)
well I know i use it with obd0, but my main concern is now im swapping to obd1 and Im hoping I wont need to use it. OBD1 doesnt use that plug correct
Old Sep 29, 2004 | 10:45 AM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al &raquo;</TD></TR><TR><TD CLASS="quote">well I know i use it with obd0, but my main concern is now im swapping to obd1 and Im hoping I wont need to use it. OBD1 doesnt use that plug correct</TD></TR></TABLE>
correct! only obd2 ecu will look for it and throw a CEL if it's not pluged up.
Old Sep 29, 2004 | 12:08 PM
Slopoke's Avatar
Tru dat see like it says below. (polish)</TD></TR></TABLE>
lol
Old Sep 29, 2004 | 01:59 PM
RyanEJ8's Avatar
Hmmmmmm........I don't have mine hooked up on my D16Y8 with OBDI ecu and harness. Also using an OBDII distributor. Everything seems to work fine.
Old Sep 29, 2004 | 09:33 PM
Default Re: Please look everyone! (RyanCivic2000)
Sounds good
Old Sep 30, 2004 | 04:16 AM
mugenhatch92's Avatar
yep CSF, no big deal just get the right harness and you will be fine
dafuzzbudd
Jul 2, 2008 05:16 PM
SlowSOHC-T
Dec 13, 2007 11:46 AM
fourdoor
10
Nov 11, 2004 12:30 PM
civic_rider
Dec 19, 2003 11:29 PM
