EG alignment question...
Well, there is no really good place to put this, so I hope that I can get an answer here...
I have a H22A Hybrid EG with some decently sticky tires on it (BFGoodrich g-Force T/A KD's). My front passenger's side lower control arm is bent (so I can't have a proper alignment done), but I have a set of GSR front LCA's on order. I've put 550 miles on the tires so far.
The tires are still in like new condition. I really want to drive my car, but I don't want to mess up my good tires. How long do you think I can go before the tires start to wear funny? I'm not burning out or anything. I just want to do some normal driving. Should I be able to drive around for another 450 miles (1000 miles in total) without causing any permanent wear-damage to them?
Thanks in advance for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krash Enbyrn »</TD></TR><TR><TD CLASS="quote">With those tires, you'd probably start seeing uneven wear soon. Just rotate your tires front to back so that the wear won't be just on one tire.</TD></TR></TABLE>
Damn...my real question then (I guess) is will putting 1000 total miles on these tires without a good alignment permanently mess up my tires even if I get my car aligned right around 1000 miles?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake »</TD></TR><TR><TD CLASS="quote">1000 miles is enough to mess them up if the toe is bad. Throw your stock rims back on or something.</TD></TR></TABLE>
this is true i had my camber set right but my toe was off by over 1inch or whatever and it was wearing the inside of my tires out in like2 months.
Thanks guys
I have put 550 miles on the tires so far, but that was all in only five days. The alignment doesn't appear to be too bad, but I know that it is not right.
I wish I could use my stock rims, but 13" steelies won't clear my GSR calipers in the front. My friend even gave me a set of 14" CRX rims, and those didn't even clear the front calipers.
I've had the tires off of the car, and I inspected them and found no wear at all...at least abnormal wear. However, if I do drive the car (just normal cruising), I won't take it over 1000 miles before I get my alignment.
My control arms should be here early next week, so at the latest that is when my alignment will be fixed. More first-hand stories would be appreciated
I have put 550 miles on the tires so far, but that was all in only five days. The alignment doesn't appear to be too bad, but I know that it is not right.I wish I could use my stock rims, but 13" steelies won't clear my GSR calipers in the front. My friend even gave me a set of 14" CRX rims, and those didn't even clear the front calipers.
Well ****! Should I risk it on $130 tires? I'm leaning towards just cruising since the tires are fine now after 550 miles, and I don't plan on putting more than 1000 on them before the car is aligned. It's a hard choice
A buddy of mine go into a fight with a curb and the curb won. Bent his LCA's, and unknown to him at the time bent his subframe a tad out of whack. He replace the tires and lca's, but due to the subframe he ate through his front right tire in almost 2 weeks. I wouldn't risk it. Just put on some spares
