Hatchback 2004
Old 09-28-2004, 12:13 PM
Default Hatchback 2004
I was thinking about buying a new car. Is it at all possible to swap the Honda Civic Si K20 with the JDM Spec RSX Type-S K20 (with the six speed hydraulic transmission)? If so what do I need, I mean, I'll need the shift linkage and probably a new gear box. But would the stick placement of the Si screw up the swap?
94HatchbackSI is offline
Old 09-28-2004, 12:15 PM
Only posers die, im next
Default Re: Hatchback 2004 (94HatchbackSI)
you need like 8,000$
nacho is offline
Old 09-28-2004, 12:18 PM
6SPD_EK's Avatar
1st off wrong forum you should have posted in the RSX/EP3 (2002+ civic si) forum
2nd you could keep your tranny but I would suggest getting a complete swap which comes with the ITR(dc5) or RSX-S tranny which is a 6spd - that is better geared for the high rev'ing jdm k20a (ITR) or k20a2 (RSX-S)
many people have already done this swap...having the shifter in the dash does not do anything
6SPD_EK is offline
Old 09-28-2004, 12:28 PM
95stangkillah's Avatar
Default Re: Hatchback 2004 (adirondackR)
Can't he just swap on the RSX head and call it a day? use the type S hardware where needed to make that work.
but why???? just put a turbo on top
95stangkillah is offline
Old 09-28-2004, 12:35 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Hatchback 2004 (nacho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nacho &raquo;</TD></TR><TR><TD CLASS="quote">you need like 8,000$ </TD></TR></TABLE>
No you don't . The ITR K20A drops right in, bolts right up to the Si transmission and requires no external modifications to work absolutely flawlessly with what's already there. So, basically, all you need is to find a K20A longblock on eBay, pull and sell your Si longblock and you'll end up with a K20A powered Si for under $3000.
Archidictus is offline
Seanyriver04
Transmission & Drivetrain
08-20-2009 09:33 AM
koolaid3246
11-13-2006 06:08 PM
94HatchbackSI
10
09-28-2004 04:03 PM
A-ivtec
03-11-2004 05:59 PM
d1deez
06-10-2003 02:03 PM
Quick Reply: Hatchback 2004
  • Ask a Question
Question Title:
Description:
