Check out my oil return...
Yes, yet another oil return question....Does this look OK? As the actual fitting on the pan looks has a slight upwards angle (slight slant towards the weld). Is this going to prevent the oil from dripping back into the pan??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot »</TD></TR><TR><TD CLASS="quote">Yes, yet another oil return question....Does this look OK? As the actual fitting on the pan looks has a slight upwards angle (slight slant towards the weld). Is this going to prevent the oil from dripping back into the pan??
it looks kinda ghetto...
try tap it with a hammer
It looks like it should be ok to me. If youre too worried about it then you could take a hammer and gently tap on it to see if you could bend it up just a **** hair more. Just be sure not to break any seals or anything. But honestly i think that it would be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by minivan81 »</TD></TR><TR><TD CLASS="quote">Looks fine.</TD></TR></TABLE>
i agree
i agree
it will be ok as long as the outlet on the oil return on the turbo is above the fitting on the oil pan. the angle of the fitting does not matter
