Messed with vortech supercharger blow off valve now car is mis firing at hi rpms
RTFM = read the ******* manual....ignore.
How did you adjust it to begin with, why not just turn it back the other way. Its just a standard Vortech BOV isnt it? Is it leaking?
the screw was loose so i was tightening he bolt. then i moved it from where it was supposed to be. now my car is misfiring at about 6k. does adjusting the bov make a car misfire?
So before you adjusted the screw, no problems. And you didnt change anything but the screw, and now you have problems. If you turned it counterclockwise 6 times, turn it back clockwise 6 times.
Im not following the problem here....
adjust, adjusting, adjustment, blow, bov, car, integra, messing, put, supercharged, supercharger, tighten, valve, valves, vortech
