fuse blowning up
Old Sep 25, 2004 | 04:28 PM
4DRmafia's Avatar
Default fuse blowning up
why does my fuse keep on blowing up for the tail lights, interior lights and my corner lights ?
Old Sep 25, 2004 | 04:33 PM
Rostr02's Avatar
Default Re: fuse blowning up (SkipMic2006)
check your positive wire it is grounding itself out or it could be your groung wire touching an open positive.
it is prob split open somewhere have you bees taking any interior pieces out and in lately?
Basically go over your wires and put the correct size amperage fuse in. Not that you havent been.
Old Sep 25, 2004 | 05:01 PM
RCautoworks's Avatar
Default Re: fuse blowning up (Rostr02)
You have a short some where, fix the problem and the fuse will not keep blowing.
Old Sep 25, 2004 | 05:05 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Check for water inside the tail lamps etc...
Especially if it has been raining or you just washed it..
Old Sep 25, 2004 | 05:15 PM
4DRmafia's Avatar
would water cause it in the lamps to short out ?
Old Sep 25, 2004 | 05:18 PM
88DXCRX's Avatar
Default Re: (SkipMic2006)
If you use a blow-dryer in the shower,will you get electrocuted?
Old Sep 25, 2004 | 05:31 PM
4DRmafia's Avatar
yes i would but anyway i just went out and check it out but no sign of water in there
Old Sep 25, 2004 | 05:51 PM
88DXCRX's Avatar
Ok,but you should probably remove the sockets from the housing and make sure..
Or shine a flashlight in there and shake the car...
It can be hard to tell sometimes..I can hit mine with the sprayer
at the car wash and watch them fill up...
Anyway,check this link: http://www.inliners.org/tech/tech6.html
It explains how to hook a test light in and from there you start unplugging
each component until the light goes out..when it does you have found your short..
Check like the taillight bulbs for broken filaments that shorted..
The easiest way to find it would be a short detector which is an RF transmitter and receiver..
Old Sep 25, 2004 | 06:06 PM
4DRmafia's Avatar
what is the rf transmitter and receiver?
Old Sep 25, 2004 | 06:17 PM
88DXCRX's Avatar
It is a Short detector which is a tool..
See that bunch of fried wire next to it?
It came from here:
Someone put a fuse that was too big in it and it fried all kinds of crap..
I fixed it all though...One wire at a time..
Old Sep 25, 2004 | 06:28 PM
4DRmafia's Avatar
oka it had the same plm last week so i change the whole wire hardness from the engine bay to behinde the firewall and it was wroking good until today it blew the fuse. i havent checked the rear or the dash wires yet and could it be 1 of them ?
Old Sep 26, 2004 | 01:15 AM
CRX Si's Avatar
do this... Unplug the rear defogger switch and put a new fuse in and try to turn the lights on... If it works you owe me a million dollars...
Old Sep 26, 2004 | 05:49 PM
importslife's Avatar
same thing happened to me it was the turn signal up front d/s it was twisted around like six times and i guess the heat from the wires dried them out and they started shorting out just one more thing to try
Old Sep 26, 2004 | 06:02 PM
4DRmafia's Avatar
i found the plm and it was hot wire touching the ground and it ended up at the rear right side tial lamp and i fixed it then it worksa after that
Old Sep 26, 2004 | 07:31 PM
glad to hear that you found the plm
Old Sep 26, 2004 | 07:50 PM
4DRmafia's Avatar
yea me 2
Old Sep 26, 2004 | 08:08 PM
W0oT's Avatar
Banned
Default Re: (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">It is a Short detector which is a tool..
DUDE!!! where did u get that i soooooo want one!!!
Old Sep 26, 2004 | 08:15 PM
Synth124's Avatar
Default Re: (Majin Vegita)
Man, it's okay, don't blow youre load. you really don't need that! I work for GM and GMC and we never use anything like that. Just a Fluke 88 and test lamp...fluke 88 rocks!
Old Sep 26, 2004 | 08:20 PM
W0oT's Avatar
Banned
Default Re: (Synth124)
i got a 77 or 87 and a crap on, your right i don't need that one, but it's badass, since it creates it's own signal, i just bought a mac one, for 10$ not all electronic and hi tech but it will work, maybe i'll be able to use it to find out why my old 4 channel amp kept shorting out.
Old Sep 27, 2004 | 09:36 AM
88DXCRX's Avatar
I borrowed it from a friend..It is a MAC tools FF300 fault finder
He said he had never used it but it worked well..
To tell the truth it just found a starting point on the nightmare pictured
above..From there I unwrapped the harness from the ignition switch
all the way to the transmission and started replacing burnt wires..
I did hook it up after the ordeal was over and it gave me a green light
though..
Old Sep 27, 2004 | 11:40 AM
urquidezj's Avatar
on mine, i looked on the fuse box and saw that the wire that goes to the front driver side corner light/blinker was fried. i had to take it all out and put new wire in.
delslow302
Apr 12, 2009 03:04 PM
slow91crxdx
May 6, 2007 08:55 AM
petergriffen
Jan 1, 2006 11:09 AM
DxBurnoutKing
Dec 20, 2005 04:30 PM
dc2lun
Feb 16, 2004 03:11 PM
