replaced clutch wont go in gear
Old Sep 24, 2004 | 10:23 PM
4thgenlude's Avatar
Default replaced clutch wont go in gear
Ive just replaced the clutch on my 92 preludes, and im sure I bolted everything back on, i replaced the cvboots, and the car starts and runs fine but, there isnt any pressure on the clutch and when I Engage it i just stays engaged and I have to reach down and pull the pedal out with my hand. I cant even put it in gear, maybe I could force it in gear but I dont want to try too hard, I dont know if itll drive if i force it in gear and try to drive it but I dont wnat to do that to my prelude.
any I deas as to what is wrong with my prelude? Slave cylinder/master cylinder neeed bleeding?
thanks alot!!
-Charlie
Modified by 4thgenlude at 1:36 AM 9/25/2004
Old Sep 25, 2004 | 03:02 AM
superturboprelude's Avatar
Default Re: replaced clutch wont go in gear (4thgenlude)
have you tried bleeding the clutch
Old Sep 25, 2004 | 06:17 AM
flyrod's Avatar
Default Re: replaced clutch wont go in gear (superjunprelude)
Ya, what he said. If you try forcing it in gear you will fry the syncros and/or break something in the shift linkage or transmission...
Old Sep 25, 2004 | 06:21 AM
Shakes's Avatar
space cadet
Default Re: replaced clutch wont go in gear (flyrod)
try to bleed the clutch. it takes a lot.
also check your shift linkages on the top of the tranny. when you say it wont go into gear maybe something is hanging up there. have someone move the shifter while you look at it. could be as small as the cotter pin hanging up on somthing.
but the pedal is just in need of a good bleed
Old Sep 25, 2004 | 06:36 AM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenlude &raquo;</TD></TR><TR><TD CLASS="quote">Ive just replaced the clutch on my 92 preludes, and im sure I bolted everything back on, i replaced the cvboots, and the car starts and runs fine but, there isnt any pressure on the clutch and when I Engage it i just stays engaged and I have to reach down and pull the pedal out with my hand. I cant even put it in gear, maybe I could force it in gear but I dont want to try too hard, I dont know if itll drive if i force it in gear and try to drive it but I dont wnat to do that to my prelude.
thanks alot!!
-Charlie
Modified by 4thgenlude at 1:36 AM 9/25/2004</TD></TR></TABLE>
sounds to me like you didnt even try to bleed it...you must every time u take the hydrolic line off
its a pain, unless u have the vacume tool like me
Old Sep 25, 2004 | 08:47 AM
4thgenlude's Avatar
Default Re: replaced clutch wont go in gear (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
its a pain, unless u have the vacume tool like me </TD></TR></TABLE>
youre right I didnt, im stupid I just followed what the Helms told me to do, I didnt even think about what I was doing really, Yeah im dumb
thanks!! im gonna go do it right now
I love this site!!
Old Sep 25, 2004 | 10:07 AM
SKDRCR's Avatar
yeah, j00 need to bleed it.
have a friend pour brake fluid (dot3 or dot4) into the clutch resevoir
whils you pump the clutch.
Keep doing it until you don't see any bubbles then tighten the screw
and you should have pressure
Old Sep 25, 2004 | 10:32 AM
Default Re: replaced clutch wont go in gear (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote"> yeah, j00 need to bleed it.
and you should have pressure </TD></TR></TABLE>
actually you need to pump it w/the screw closed, then hold it down while your friend opens the valve, then tighten valve, pump, hold down, open, close...repeat till you have full pressure
Old Sep 25, 2004 | 10:42 AM
SKDRCR's Avatar
actually you need to pump it w/the screw closed, then hold it down while your friend opens the valve, then tighten valve, pump, hold down, open, close...repeat till you have full pressure</TD></TR></TABLE>
hmm, that's probably why it took me longer
Old Sep 25, 2004 | 12:04 PM
4thgenlude's Avatar
Im soooo happpy I finally Got her back up and running!!!!
thanks for the help!!
Old Sep 25, 2004 | 12:50 PM
LudeyKrus's Avatar
Not if you use a brake bleeder bottle
And damn you and your little vacuum bleeder too!
Old Sep 27, 2004 | 05:53 AM
flyrod's Avatar
Default Re: replaced clutch wont go in gear (LudeyKrus)
Thanks for posting back! Not too many ppl post results of advice they get here. It's nice to see we were able to help.
Old Sep 27, 2004 | 09:38 AM
prelude1897's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for posting back! Not too many ppl post results of advice they get here. It's nice to see we were able to help.</TD></TR></TABLE>
exactly
Old Sep 30, 2004 | 12:42 PM
4thgenlude's Avatar
thats because im greatfull!!!
Old Oct 2, 2004 | 11:17 AM
PrettyLude's Avatar
next time when your bleeding it, and if there is no pressure, help the slave cylinder by taking something and prying against it to go in the position it normally does, it will be faster that way
Old Oct 5, 2004 | 09:30 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superjunprelude &raquo;</TD></TR><TR><TD CLASS="quote">have you tried bleeding the clutch</TD></TR></TABLE> buah ha ha ha ha....this would be a good thing to do.
jwshilli
Jul 14, 2009 03:02 PM
codybb4
Dec 9, 2008 08:44 AM
t0mmysays
Jul 6, 2006 10:21 PM
93dx
Feb 3, 2005 02:40 PM
flip1199
Jul 29, 2002 02:14 PM
