From the Ground Up. Build Thread.
Old Jun 15, 2017 | 05:07 PM
  #126
jdblock's Avatar
Default Re: From the Ground Up. Build Thread.
Fuel pump going bad?
Random low idle, but doesn't die.
Cruising around, major loss of power, like a hiccup, then drives like normal. Happened 4-5 times within one mile from home.
My fuel gauge doesn't work, and I probably drive around with under 1/4 tank often.
Old Jul 31, 2017 | 02:12 PM
  #127
jdblock's Avatar
Spent some time installing some fog lights and cleaning the car this weekend. While I was running wires, I got the idea to put the radio's USB line in the lighter. I had it going to the glove and didn't like it there.
I had a USB charger installed into the lighter socket, and figured I can strip the guts and install the radio's USB cord instead.
So I stripped the adapter and the lighter socket, ran the radio cord through the back of the lighter socket and put it into the USB adapter housing, then popped that into the lighter socket and all was done.
I didn't take any real pictures while tackling this, but here you can see the radio USB going into the back of the lighter socket, and the ipod cable plugged into the front.
And a shot with the covers back on and cleaned.
I disconnected the power going to the socket, and now want to install a couple USB chargers off that line, just have to figure out where I want the USB ports.
Old Jan 16, 2018 | 08:27 PM
  #128
jdblock's Avatar
It's almost time.
Old Jan 18, 2018 | 11:19 AM
  #129
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Originally Posted by jdblock
It's almost time.
Time for???
Old Jan 18, 2018 | 02:59 PM
  #130
tony_2018's Avatar
Fish Twig
It's almost time.
K
Old Jan 19, 2018 | 08:41 AM
  #131
jdblock's Avatar
Originally Posted by 94 Civic Si
Time for???
the awakening.
Old Jan 28, 2018 | 06:05 PM
  #132
jdblock's Avatar
Been working on the car a little bit. Getting ready for smog and making it nicer to drive around.
Went to pick-n-pull and grabbed a bunch of stock parts I wanted. Bought an Integra shift lever, ICU module, and stock intake. I was missing an antenna, so I went ahead and picked one of those up as well.
It's smog time again, so off with the cheaply made noise makers, and install the ugly over engineered OEM parts. I actually like how the engine bay looks with all the stock stuff. Stock header makes some nice midrange power compared to the 4-1 I had in there, feels really nice as a daily right now. I installed a stock air intake from an Integra LS, including the pre-filter snorkel, and bought a new NAPA air filter. One thing you've got to like about OEM parts, they just work.
I had made a fancy shift extender, but the cheap cast aluminum ebay short shifter kept breaking on hard shifts. Well, it's been broken and repaired a few times, and was getting too short to be functional. So, I pulled a dual bend shifter from an Integra LS, ground it down to fit my linkage and installed it.
I've been tired of not having an intermittent wiper speed (CX chassis), so I searched the interweb for the solution to my frustrations. I found a simple guide that required almost no parts or thought, and I went for it. Since my combination switch had already been swapped for one with the "INT" wiper setting, I needed to pick-up what I guess is the brains of the operation from an Integra. So after swapping in one box for another, and moving a few wires around, I've been graced with wipers that are not too slow nor too fast.
link;
https://honda-tech.com/forums/honda-...folks-2749779/
Old Jan 29, 2018 | 07:04 AM
  #133
Premium Member
Loved
Community Favorite
It is nice when stuff just works...
Good stuff!
Old Jan 30, 2018 | 11:23 PM
  #134
jdblock's Avatar
I've had this battery tie down for the longest time, and have never used it because it's pink and didn't go with anything. Had an idea, and here it goes. Decided to just sand it and give it a brushed look. Some 120 sandpaper and a bit of thought, and it turned out to be fairly easy. Just took a lot of time to sand out the imperfections.
In this picture: about half way done with the first step of sanding. Sanded down the high spots, now to sand out the low spots.
In this picture: after the last sanding and waiting to be installed.
Old Jan 31, 2018 | 01:30 PM
  #135
Josip.'s Avatar
5 Year Member
This looks gorgeous!
Old Jan 31, 2018 | 06:52 PM
  #136
jdblock's Avatar
Pulled the battery and inspected everything around it. The battery tray is obviously in need of attention.
Pulled the tray and got as much rust off as I could in 10 minutes. I then coated the entire thing in a spray on rubber undercoating (for cars) and just encased all the rust I could. This will be a short term fix.
While I had the tray out, I decided to pull the fuse box as well and give it all a good cleaning. I like using this brush to get in and around everything that I can.
Found a little rust on the body. Guess I should make plans to fix that.
Old Jan 31, 2018 | 10:52 PM
  #137
Josip.'s Avatar
5 Year Member
Nice work. Now just change those clamps for something cool and thats it.
Btw, how did you get that finish on batery stay? Its like the back of some phones, like LG L3 or similiar.
Old Jan 31, 2018 | 11:11 PM
  #138
jdblock's Avatar
Thank you.
120 grit sand paper and about 4.5 hours of work. There's probably a better way, or a tool, that'll get it done faster, but I like doing it slow.
Old Feb 11, 2018 | 06:22 PM
  #139
jdblock's Avatar
More brushed. It's becoming a thing.
Old Feb 12, 2018 | 08:01 AM
  #140
Premium Member
Loved
Community Favorite
Looks nice! Do you need to coat after the brushing to protect from corrosion?
Old Feb 12, 2018 | 04:47 PM
  #141
jdblock's Avatar
You can put a clear coat on after you're done. I didn't because I read some funny stuff happens and the clear can peel and chip off, and I wanted to be able to just touch-up the brushing if I wanted.
Maybe a wax coating would work against corrosion, and not chip and peel? I might have to try it out.
Old Feb 14, 2018 | 05:27 AM
  #142
Chuii Rodriguez's Avatar
This was a very interesting read. I like it very well put.
Old Feb 20, 2018 | 06:52 AM
  #143
CandyRedRC46's Avatar
Maybe a light coat of oil or aluminum polish from time to time would do the trick.
Old Feb 20, 2018 | 07:31 AM
  #144
tony_2018's Avatar
Fish Twig
I'd clear coat but hey, OP has his own methods.
Old Feb 20, 2018 | 05:25 PM
  #145
jdblock's Avatar
I'm still thinking about it. Gotta go find some matte clear and do a sample piece first. I've never done something like this to metal, I don't know what is best.
Old Feb 20, 2018 | 05:27 PM
  #146
jdblock's Avatar
I'm not even worried about corrosion, It's aluminum. Doesn't really matter what I do to it.
Old Feb 22, 2018 | 08:33 PM
  #147
jdblock's Avatar
Old Feb 25, 2018 | 09:20 PM
  #148
jdblock's Avatar
Old Feb 27, 2018 | 12:08 PM
  #149
jdblock's Avatar
Old Feb 27, 2018 | 12:36 PM
  #150
Josip.'s Avatar
5 Year Member
Can you explain the last photo?
