fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc.
Not a scratch on the bed. Bad lighting.
NEW PICS UP OF WHAT IS LEFT AND I DISASSEMBLED THE BLOCK.
NOTE:ONE OF THE BLOCKS CYLINDER SLEEVES HAS SCRATCHES DUE TO DROPPING A VALVE AND ONE PISTON IS BAD. If no1 wants the block as is, I am going to have it bored this week and sell it like that. I can have it bored for you and ship it if you want.
Off of a 2002 rsx-s k20a2
ac pump 20k miles.... I didn't use it with my swap.
Everything else has 21xxx miles
Heres a pic of the altered ps pump. I used ps in my swap so I used the integra fitting, turned it backwards and countersunk a screw in it to clear the hood. Works perfect, no leaks.
Water pump SOLD to kommon_sense
slave cylinder with hard and soft line. SOLD to kommon_sense
flywheel and bolts- SOLD to kommon_sense
fuel rail $40 shipped
knock sensor SOLD to kommon_sense
rods with pistons attatched (1 piston bad) $80 shipped
crank SOLD TO CHEETAH
bare block $125 shipped
oil pump with pickup SOLD to hotwheelz
windage tray SOLD to hotwheelz
ps pump $40 shipped
ac pump $75 shipped
timing chain guides $20 shipped
Timing chain cover $35 shipped
clutch assembly with bolts $70 shipped
ETC...... anything pictured above
Modified by 6_GeArEd_TEG at 3:41 AM 12/25/2005
Modified by 6_GeArEd_TEG at 8:06 PM 12/28/2005
Modified by 6_GeArEd_TEG at 2:49 AM 1/3/2006
Modified by 6_GeArEd_TEG at 2:58 AM 1/3/2006
Modified by 6_GeArEd_TEG at 11:08 PM 1/4/2006
Modified by 6_GeArEd_TEG at 11:15 PM 1/4/2006
Modified by 6_GeArEd_TEG at 11:59 PM 1/21/2006
Modified by 6_GeArEd_TEG at 12:09 AM 1/22/2006
Modified by 6_GeArEd_TEG at 12:13 AM 1/22/2006
Modified by 6_GeArEd_TEG at 12:16 AM 1/22/2006
Modified by 6_GeArEd_TEG at 11:38 PM 1/24/2006
Modified by 6_GeArEd_TEG at 1:04 AM 2/4/2006
Modified by 6_GeArEd_TEG at 11:31 PM 2/8/2006
Modified by 6_GeArEd_TEG at 4:33 PM 6/14/2006
Modified by 6_GeArEd_TEG at 1:24 PM 8/4/2006
Modified by 6_GeArEd_TEG at 2:02 PM 8/4/2006
Modified by 6_GeArEd_TEG at 2:21 PM 8/4/2006
Modified by 6_GeArEd_TEG at 3:57 AM 8/6/2006
Modified by 6_GeArEd_TEG at 3:42 PM 8/6/2006
Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (6_GeArEd_TEG)
u have a primary 02 air/fuel sensor for a k20a?
Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (RhdRicheeee)
I already sold that, I have the heated o2 sensor or whatever it is I believe.
Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (EFDawg)
i will take the flywheel. is that the stock flywheel or aftermarket let me know i want it
Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (BIGGINS LS-VTEC)
It has some scratches in the cylinder sleeve that dropped a valve. There not too deep, but I dunno how deep is too much. If you plan on boring it over it should be fine. Shipping would be $100 ups on it, and thats if I can build a box for it and it weighs less than 100lbs. A guy offered me $300 plus shipping for it, but I dunno if he still wants it. I'd do 350 shipped on it. With the crank, rods and pistons still in it.
ok let me know some thing ... doyou know the condition of the rods and crank if there bent or not ?
I don't know if anything is bent. I was gonna take it apart if some1 wanted the crank, but as it sits now the oil pump and windage tray are still on it. I guess its up for grabs since the guy hasn't emailed me back.
Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (kommon_sense)
I do, but since I had this swap in an integra, I had to use the integra fitting the hose runs to on the top of the pump, turn it around, and counter sunk a screw in it to get it to clear the hood. It works, and doesn't leak. I can snap a pic if you want. I'd ship it to u for $30.
