fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc.
Old 12-24-2005, 06:05 PM
6_GeArEd_TEG's Avatar
Default fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc.
Not a scratch on the bed. Bad lighting.
NEW PICS UP OF WHAT IS LEFT AND I DISASSEMBLED THE BLOCK.
NOTE:ONE OF THE BLOCKS CYLINDER SLEEVES HAS SCRATCHES DUE TO DROPPING A VALVE AND ONE PISTON IS BAD. If no1 wants the block as is, I am going to have it bored this week and sell it like that. I can have it bored for you and ship it if you want.
Off of a 2002 rsx-s k20a2
ac pump 20k miles.... I didn't use it with my swap.
Everything else has 21xxx miles
Heres a pic of the altered ps pump. I used ps in my swap so I used the integra fitting, turned it backwards and countersunk a screw in it to clear the hood. Works perfect, no leaks.
Water pump SOLD to kommon_sense
slave cylinder with hard and soft line. SOLD to kommon_sense
flywheel and bolts- SOLD to kommon_sense
fuel rail $40 shipped
knock sensor SOLD to kommon_sense
rods with pistons attatched (1 piston bad) $80 shipped
crank SOLD TO CHEETAH
bare block $125 shipped
oil pump with pickup SOLD to hotwheelz
windage tray SOLD to hotwheelz
ps pump $40 shipped
ac pump $75 shipped
timing chain guides $20 shipped
Timing chain cover $35 shipped
clutch assembly with bolts $70 shipped
ETC...... anything pictured above
Modified by 6_GeArEd_TEG at 3:41 AM 12/25/2005
Modified by 6_GeArEd_TEG at 8:06 PM 12/28/2005
Modified by 6_GeArEd_TEG at 2:49 AM 1/3/2006
Modified by 6_GeArEd_TEG at 2:58 AM 1/3/2006
Modified by 6_GeArEd_TEG at 11:08 PM 1/4/2006
Modified by 6_GeArEd_TEG at 11:15 PM 1/4/2006
Modified by 6_GeArEd_TEG at 11:59 PM 1/21/2006
Modified by 6_GeArEd_TEG at 12:09 AM 1/22/2006
Modified by 6_GeArEd_TEG at 12:13 AM 1/22/2006
Modified by 6_GeArEd_TEG at 12:16 AM 1/22/2006
Modified by 6_GeArEd_TEG at 11:38 PM 1/24/2006
Modified by 6_GeArEd_TEG at 1:04 AM 2/4/2006
Modified by 6_GeArEd_TEG at 11:31 PM 2/8/2006
Modified by 6_GeArEd_TEG at 4:33 PM 6/14/2006
Modified by 6_GeArEd_TEG at 1:24 PM 8/4/2006
Modified by 6_GeArEd_TEG at 2:02 PM 8/4/2006
Modified by 6_GeArEd_TEG at 2:21 PM 8/4/2006
Modified by 6_GeArEd_TEG at 3:57 AM 8/6/2006
Modified by 6_GeArEd_TEG at 3:42 PM 8/6/2006
6_GeArEd_TEG is offline
Old 12-24-2005, 06:06 PM
RhdRicheeee's Avatar
Default Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (6_GeArEd_TEG)
u have a primary 02 air/fuel sensor for a k20a?
RhdRicheeee is offline
Old 12-24-2005, 06:09 PM
Default Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (RhdRicheeee)
I already sold that, I have the heated o2 sensor or whatever it is I believe.
Old 12-24-2005, 06:17 PM
cheesebox's Avatar
do you still have the vtc ? if so how much you want for it? pm me
cheesebox is offline
Old 12-24-2005, 07:34 PM
Default Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (cheesebox)
pm'd
Old 12-25-2005, 07:50 AM
BUMP
Old 12-26-2005, 02:00 PM
bump
Old 12-27-2005, 02:21 PM
up
Old 12-28-2005, 09:37 PM
kommon_sense's Avatar
How much for the flywheel shipped to 27703? Thanks.
kommon_sense is offline
Old 12-30-2005, 01:34 PM
Default Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (kommon_sense)
60 shipped
Old 01-02-2006, 07:34 AM
EFDawg's Avatar
Hey man, PM me with what you have and how much you want for it.
EFDawg is offline
Old 01-02-2006, 10:05 AM
willie0315's Avatar
Default Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (EFDawg)
i will take the flywheel. is that the stock flywheel or aftermarket let me know i want it
willie0315 is offline
Old 01-02-2006, 02:03 PM
Default Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (willie0315)
stock flywheel
Old 01-02-2006, 02:10 PM
sent you an e-mail. shoot me your paypal and I can send you payment.
Old 01-02-2006, 05:46 PM
replied
Old 01-04-2006, 02:10 PM
UP
Old 01-05-2006, 06:15 AM
BIGGINS LS-VTEC's Avatar
is the block its self still good ? if so how uch shipped to 21222 ?
BIGGINS LS-VTEC is offline
Old 01-05-2006, 12:03 PM
Default Re: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc. (BIGGINS LS-VTEC)
It has some scratches in the cylinder sleeve that dropped a valve. There not too deep, but I dunno how deep is too much. If you plan on boring it over it should be fine. Shipping would be $100 ups on it, and thats if I can build a box for it and it weighs less than 100lbs. A guy offered me $300 plus shipping for it, but I dunno if he still wants it. I'd do 350 shipped on it. With the crank, rods and pistons still in it.
Old 01-06-2006, 08:13 AM
ok let me know some thing ... doyou know the condition of the rods and crank if there bent or not ?
Old 01-07-2006, 07:39 PM
I don't know if anything is bent. I was gonna take it apart if some1 wanted the crank, but as it sits now the oil pump and windage tray are still on it. I guess its up for grabs since the guy hasn't emailed me back.
Old 01-07-2006, 07:44 PM
you still have the power steering pump?
Old 01-07-2006, 08:01 PM
I do, but since I had this swap in an integra, I had to use the integra fitting the hose runs to on the top of the pump, turn it around, and counter sunk a screw in it to get it to clear the hood. It works, and doesn't leak. I can snap a pic if you want. I'd ship it to u for $30.
Old 01-08-2006, 11:43 AM
bump
Old 01-08-2006, 12:53 PM
so how much are you asking for the bottom end ?
Old 01-08-2006, 02:11 PM
325 shipped
Quick Reply: fs: k20a2 junk. dead block, fuel rail, ac pump, clutch, flywheel etc.
