Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
normal operating temperature of d16z6
Old Aug 18, 2006 | 11:45 AM
OpTiX619's Avatar
Default normal operating temperature of d16z6
searched but did not find a difinitive answer. what is the highest temp that the car should reach before I start getting worried? 220F?
Thanks,
dan
Old Aug 18, 2006 | 07:23 PM
OpTiX619's Avatar
Default Re: normal operating temperature of d16z6 (OpTiX619)
ttt
Old Aug 21, 2006 | 11:00 PM
civicrr's Avatar
IIRC, the thermo opens fully @ 195 F. 220 seems pretty hot to me. I want to say my car, with Integra radiator, never sees 200 even when racing nose to tail. This is with a HC4 build on the motor running a oil cooler.
With the old Fluidyne Civic radiator (1/2 width), even with a block off plate on the a/c side, it ran close to 220.
Old Aug 22, 2006 | 04:47 AM
roppetty's Avatar
my fans turn on at 210ish i believe, might be around 220. i see 220 when i'm driving hard and stop, but it doesnt stay up there for long. driving hard it's around 200ish, maybe a little less. if they're supposed to come on 195, i have a problem then, lol. need to check the service manual i guess
edit - just checked my haynes, it does say the thermostat opens at 195, so 220 may be too hot
Old Jun 14, 2023 | 12:13 AM
Canopa's Avatar
Hi, my car running normal, but my radiator fan turn on at around 230 f what should I do?
Old Jun 14, 2023 | 07:41 AM
Kaan's Avatar
Loved
Community Favorite
you need to check to make sure your gauges are correct, maybe replace the fan temperature sensor, and if you have hondata, check the settings to make sure the temperature is set where you want it.
Old Jul 30, 2023 | 01:01 PM
dirty19's Avatar
Ridin Dirty in Cali
When I had my D16Z6 I used a Mishimoto Integra radiator and dual fans on a dedicated switch.
Even on the hottest days on track would it ever get past 210.
Old Aug 2, 2023 | 04:07 AM
Canopa's Avatar
Thanks.. I see now.. I just got the bluetooth datalogger installed, and it's showing that my temperature sensor reading -27' it's been like that all these years omg.. engine check not showing.. just replaced the temp sensor and everything works flawlessly
Nice.. That's a great idea to use a dedicated switch!
preetyboi06
14
Aug 26, 2011 03:05 PM
iamthefollower
Mar 17, 2011 04:55 PM
Dybowski
Mar 18, 2009 12:28 PM
Panda Eg6
Jul 17, 2007 04:09 PM
jdmCivic925
Jul 7, 2006 01:06 PM
