Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Eibach "25.4mm" sway bar?
Old 09-10-2013, 09:56 AM
Franshow's Avatar
Default Eibach "25.4mm" sway bar?
Does anyone know how to get a hold of one of these? I know that JHPusa sells the black ones but supposedly there are some ITR specific 25mm red sway bar available. Thanks
Old 09-10-2013, 10:07 AM
Xian's Avatar
Default Re: Eibach "25.4mm" sway bar?
If you can't find one of these, maybe go with the thin wall hollow ASR bar? Roughly the same rate...
Old 09-10-2013, 01:57 PM
Jackson's Avatar
I told you that you could PM me, vtecvoodoo or JReyes to get one direct from us if JHP couldn't get you one. Options Auto or even Evasive has sold these bars too.
If you have ITR rear LCAs you'll want the red bar we currently have. The black bars are for the thinner GSR and EK rear LCAs which were then updated to fit all LCAs.
Old 09-10-2013, 07:54 PM
Franshow's Avatar
^ My buddy told me you were on here after I had made this thread, my bad. I had lost all of our emails by mistake (deleted them unintentionally) and didn't want to bug you with the same exact questions on NWP/FB again lol, so I tried my luck in seeing who had acquired it on this page.
Old 09-11-2013, 07:57 AM
Jackson's Avatar
Fran, not a problem! This bar isn't cataloged or really even distributed so we don't mind giving HT peeps a discount directly on this particular part.
Old 09-12-2013, 06:17 AM
Franshow's Avatar
Thanks alot Jackson, when I'm ready I will contact you directly
Old 09-12-2013, 06:52 AM
Xian's Avatar
Is that a hollow or solid bar?
Old 09-12-2013, 11:34 AM
Jackson's Avatar
Here's a quick comparison to the ITR 22mm bar and a picture of it installed.
OE ITR bar: 22 mm (0.87 in) solid
OE measured bar rate: 51 N/mm (292 lbs/in)
OE bar weight: 3.78 kg (8.4 lbs)
Eibach bar: 25 mm (1 in) Tubular & 3 Way Adjustable
Part# 4086.312
Eibach measured bar rate:
Position 1 = 73 N/mm (418 lbs/in) +43%
Position 2 = 94 N/mm (533 lbs/in) +84%
Position 3 = 111 N/mm (630 lbs/in) +118%
Eibach bar weight: 3.15 kg (7.0 lbs)
Old 09-12-2013, 11:50 AM
Xian's Avatar
Nice. So it's comparable (stiffness) to the 24mm solid but weighs quite a bit less. Solid.
Old 09-12-2013, 03:41 PM
descartesfool's Avatar
No, hollow!
Old 09-13-2013, 06:48 AM
Xian's Avatar
Your comments ring hollow in my ears...
Old 05-21-2015, 07:37 PM
cheapskate's Avatar
Can anyone confirm what the part number is for the red bar that works with ITR lcas?
The # 4086.312 bar is listed on jhpusa.com as "not compatible with ITR lcas."
https://www.jhpusa.com/store/pc/view...dcategory=1822
Thanks.
kulo
Suspension & Brakes
20
01-25-2009 10:02 PM
4CDFED
05-08-2007 11:16 PM
SaYjAiBaO
10-26-2006 05:58 PM
ABTDer
07-21-2003 11:02 AM
mamaboy
11-17-2001 06:49 AM
Quick Reply: Eibach "25.4mm" sway bar?
