Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
ECU's for Improved Touring
Old Dec 13, 2001 | 05:45 PM
sjasmund's Avatar
Default ECU's for Improved Touring
I’m waiting for the 2002 ITCS (IT rules) to come out so I can see the final wording but it looks like ECU’s will be opened up for Improved Touring next year. I’m looking at options… does anyone have experience with the Zdyne SuperECU?
I’ve spoken with Zdyne and they acknowledge that it’s aimed primarily at the turbo/nitrous/straight-line crowd but he still felt we’d find horsepower using one if we spent enough time on the dyno tweaking.
Has anyone used one?
Old Dec 13, 2001 | 06:14 PM
GSRMatt's Avatar
25 Year Member
Default Re: ECU's for Improved Touring (sjasmund)
Never used a z-dyne, but I bet with any aftermarket ECU that will let you bump/retard timing a couple degrees, and fuel % up/down, you'll be able to find 3-5 hp, especially up top. You won't need anything particularly complicated. Just spend a few hours on a load bearing dyno and I bet you'll show results across the board.
Old Dec 13, 2001 | 08:56 PM
Crack Monkey's Avatar
Check http://www.improvedtouring.com - there was discussion there of an ECU that does not use an open loop mode - the sensors can read fast enough to use them at all rpm and load ranges. Don't remember any details though.
Old Dec 14, 2001 | 04:16 AM
StageOne's Avatar
May want to check out the Hondata unit www.hondata.com. Some people on the Type R board have used it with success.
fuzzysig
Engine Management and Tuning
Jan 26, 2017 07:02 AM
enemy no1
Jan 12, 2011 10:02 AM
standbackimapro
Jan 17, 2006 10:41 AM
TypeR Chris
Jan 20, 2004 12:40 PM
marklamond
Jun 13, 2003 07:02 PM
