Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
downshifting....
Old Aug 16, 2003 | 06:54 PM
vultron's Avatar
Default downshifting....
ok i just got a clutchmasters 7.5 lightweight aluminum flywheel for my b18c1 swap. now my buddy says that its unsafe to downshift when im @ high RPMs. is there any truth to what he says?
Old Aug 16, 2003 | 07:58 PM
Tweakmeister's Avatar
Default Re: downshifting.... (vultron)
no
Old Aug 16, 2003 | 07:59 PM
krshultz's Avatar
An aftermarket clutch won't make any difference in how "safe" (I'm assuming he was referring to the risk of overrevving the motor) it is to downshift at a certain RPM. However, if you're not revmatching, an aftermarket clutch will make the lurch you feel much more dramatic. I just can't think of a reason why an aftermarket clutch would make downshifting less "safe."
EDIT: DOH, I just read "flywheel," not "clutch." This might make things different (I'm really grasping here)...if the flywheel is known to be fragile, I suppose its possible that the aforementioned "shock" to the drivetrain could cause the thing to grenade. I've certainly heard of people grenading aluminum flywheels...hence the need for a "Scatter Shield" or some such thing.
Old Aug 16, 2003 | 09:03 PM
manveer's Avatar
It really depends at what RPMs you downshift. Downshifting at 8000 RPMs (a bit extreme) or something would obviously be bad no matter what flywheel you have.
Old Aug 16, 2003 | 09:19 PM
.RJ's Avatar
.RJ
Default Re: downshifting.... (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">no</TD></TR></TABLE>
dk4ever
Nov 24, 2008 07:52 AM
Lauj87
Sep 17, 2005 06:32 PM
SLATER97EX
Nov 17, 2004 02:16 PM
honcrx91si
May 17, 2004 05:01 PM
Heinz57
12
May 26, 2003 04:34 AM
