Questions
Old 05-02-2010, 01:15 PM
qb1291's Avatar
Default Questions
I am about to start body work and paint on my 96 Integra LS. I had a couple questions about it.
Can I do the body work and only prime the areas where I do the work? I am then going to put down a black sealer over the top of that, and then I ws going to shoot the base and clear. The car is going from white to supersonic blue pearl.
Any help would be appreciated.
Old 05-02-2010, 04:10 PM
00sihok's Avatar
Default Re: Questions
yes you can prime the areas you fix. just feather the edge when you finish sand for your sealer. are you sealing the whole car before you paint or just those areas? sealing the whole car for the color change will give you better coverage and less coats of paint to hide the repair areas.
Old 05-02-2010, 05:14 PM
qb1291's Avatar
I plan on sanding down the original base and then sealing the whole car with black sealer. I want to try and get a deeper, and darker tint do the ssbp.
qb1291
Paint and Body
02-25-2010 12:07 PM
beginmyhonda
Paint and Body
07-24-2009 02:45 AM
jdmteg96
06-15-2005 12:25 AM
oldskooljdm
12-16-2003 07:24 AM
Quick Reply: Questions
