Questions
I am about to start body work and paint on my 96 Integra LS. I had a couple questions about it.
Can I do the body work and only prime the areas where I do the work? I am then going to put down a black sealer over the top of that, and then I ws going to shoot the base and clear. The car is going from white to supersonic blue pearl. Any help would be appreciated. |
Re: Questions
yes you can prime the areas you fix. just feather the edge when you finish sand for your sealer. are you sealing the whole car before you paint or just those areas? sealing the whole car for the color change will give you better coverage and less coats of paint to hide the repair areas.
Re: Questions
I plan on sanding down the original base and then sealing the whole car with black sealer. I want to try and get a deeper, and darker tint do the ssbp.
