Question on sand/paint
Old Mar 12, 2008 | 09:07 AM
91_civic_si's Avatar
Default Question on sand/paint
well i have a car that i ended up painting not to long ago like 6 months or so and it was just a flat black no clear coat. I was wondering if i could sand the whole car with a thin grit to even the color out, there are some spots that are darker then others and i left it out side for the winter with a car cover on it and when i pulled the cover off some spots got stuck onto the frame and i was just wondering if it would be okay just to sand the whole car down with a thin grit to even out the color. So any advice would help and thanks....
Modified by 91_civic_si at 11:16 AM 3/12/2008
Old Mar 12, 2008 | 01:04 PM
iam7head's Avatar
Default Re: Question on sand/paint (91_civic_si)
a proper flat black job will have a clearcoat
so what did you use?
Old Mar 12, 2008 | 08:14 PM
Pockets's Avatar
If you sand it there will be sanding marks, and you can't buff it so I wouldn't recomend it. If it's still in basecoat I'm assuming, just wet sand it with 600 lightly by hand and have the panels reshot to match. I would also recomend a satin clear so this doesn't happen again.
Old Mar 13, 2008 | 04:10 AM
RoadRage212's Avatar
Default Re: (Pockets)
^ X2
But don't apply clearcoat unless you plan to do it to the whole car. Otherwise it'll look like crap.
Old Mar 14, 2008 | 08:09 AM
Default Re: (RoadRage212)
well thanks guys. for the info always helps to get advice instead of dicks trying to think they know everything.. but yeah i just wanted to keep it flat black but will re pait it...
blackmugensivic
Paint and Body
Apr 29, 2011 05:06 PM
HondaGuy4Life
Paint and Body
Jul 30, 2008 01:11 AM
sandturtle
Paint and Body
Apr 18, 2008 08:57 PM
steak
Paint and Body
Jul 20, 2007 11:50 AM
b16awarrior
Oct 29, 2002 06:11 AM
