Problems with painting
Old Apr 24, 2011 | 07:40 PM
blackmugensivic's Avatar
Default Problems with painting
First off this is the first time I have ever painted a car. I printed off the "how too" guide from the faq.
Now for my problem, I prepped the car and got it primed then did the guide coat with some regular black spray paint (light mist on the car yet enough to see), now my problem is that I was unsure if the entire guide coat had to be sanded off, stupid me thought I would be ok not sanding everything off and now there are some slightly darker "streaks" in the base coat from the black paint.
My question is can I put more coats of base color to make them "go away" or am I screwed and need to sand the car down again and basically start over?
Any input will be appreciated.
Old Apr 29, 2011 | 10:36 AM
marvelgrrr's Avatar
Default Re: Problems with painting
How many coats have you already put on? You didn't clear it yet right? I would sand down with 800grit have give it another coat or two.
Old Apr 29, 2011 | 10:57 AM
jasoncrashtech's Avatar
if you still have guide coat on your primer then your panel wont be straight.
if i was you i would block it out straight and re prime.
Old Apr 29, 2011 | 12:18 PM
Hawkze_2.3's Avatar
The remaining guide coat indicates low spots, and those should have been fixed before painting.
You can still wet sand and buff it out, but more than likely all those areas will show in the body work as low spots.
Old Apr 29, 2011 | 05:06 PM
(. )( .)'s Avatar
so you put base coat over the guide coat? yes that should have been used for highs and lows only. you had to sand it all off, repair, primer...
I'm no expert but thats what i would have done.
98civdx
Detailing
21
May 7, 2010 07:52 PM
HondaGuy4Life
Paint and Body
Jul 30, 2008 01:11 AM
Ep1dem1c
Paint and Body
Jul 31, 2007 12:04 AM
supaman111
Welding / Fabrication
16
Aug 5, 2005 05:47 AM
2001gsRguy2
Apr 30, 2003 04:50 AM
