Autometer Phantom Gauges
Old Feb 19, 2004 | 03:47 PM
prostreetonline's Avatar
Default Autometer Phantom Gauges
Autometer Phantom gauges are a white faced gauge with a black bezel. The most popular versions are available below in a standard 52mm(2 1/16in). Other gauges in this series are available; they also come in the larger 60mm (2 3/8in) size.
2" BOOST, 30 IN. HG/20 5701 $63.75
2" BOOST, 30 IN. HG-VAC/ 5703 $63.75
2" BOOST, 0-35 PSI, 5704 $59.37
2" FUEL PRESS, 0-100 PSI 5712 $57.55
2" OIL PRESS, 0-100 PSI, 5721 $55.12
2" OIL PRESS, 0-150 PSI, 5723 $56.19
2" NITROUS, 0-1600 PSI, 5728 $82.36
2" WATER TEMP, 140-280`F 5731 $71.21
2" WATER TEMP, 120-240`F 5732 $73.62
2" OIL TEMP, 140-280`F, 5741 $73.62
2" VACUUM, 30 IN. HG, 5784 $52.29
2-5/8" BOOST, 30 IN. HG/ 5801 $62.58
2-5/8" BLOWER PRESS, 0- 5802 $62.58
2-5/8" BOOST, 30 IN. HG/ 5803 $64.32
2-5/8" FUEL PRESS, 0-15 5810 $52.57
2-5/8" FUEL PRESS, 0-100 5812 $52.57
2-5/8" FUEL PRESS, 0-15 5813 $146.02
2-5/8" OIL PRESS, 0-100 5821 $50.66
2-5/8" OIL PRESS, 0-200 5822 $53.88
2-5/8" OIL PRESS, 0-150 5823 $53.88
2-5/8" NITROUS, 0-1600 5828 $84.89
2-5/8" WATER TEMP, 140-280 5831 $81.11
2-5/8" WATER TEMP, 120-240 5832 $83.35
2-5/8" OIL TEMP, 140-280 5841 $81.73
2-5/8" TRANS TEMP, 140-280 5851 $84.42
2-5/8" VACUUM, 30 IN. HG 5884 $54.41
3-3/8" OIL PRESS, 0-100 5829 $71.15
3-3/8" WATER TEMP, 140-280 5839 $99.02
2" FUEL LEVEL, 0 E/90 F, 5714 $49.77
2" FUEL LEVEL, 73 E/8-12 5715 $49.77
2" FUEL LEVEL, 240 E/33F 5716 $49.77
2" FUEL LEVEL, 0 E/30 F, 5717 $49.77
2" FUEL LEVEL, 16 E/158F 5718 $49.77
2" OIL PRESS, 0-100 PSI, 5727 $65.42
2" WATER TEMP, 100-250`F 5737 $56.46
2" OIL TEMP, 100-250`F, 5747 $57.22
2" TRANS TEMP, 100-250`F 5757 $57.22
2" CLOCK, 12 VOLT, ELEC, 5785 $64.95
2" VOLTMETER, 8-18 VOLTS 5791 $49.01
2-1/16" E.G.T. PYROMETER - need 5744 5743 $99.44
2" E.G.T. KIT, 0-1600`F, probe and wire 5744 $138.82
2" FUEL PRESS, 0-15 PSI, 5761 $211.17
2" FUEL PRESS, 0-100 PSI 5763 $211.17
2" E.G.T. PYROMETER, 2-channel 5766 $243.62
2" INTAKE TEMP, 30-300`F 5772 $222.27
2" INTAKE TEMP, 30-400`F 5773 $280.90
2" NITROUS, 0-1600 PSI 5774 $194.22
2" AIR/FUEL RATIO 5775 $64.32
2" BOOST-VAC, 30 IN. HG/ 15 psi peak / hold 5776 $173.97
2" BOOST-VAC, 30 IN. HG/ 30psi peak / hold 5777 $179.73
2-5/8" E.G.T. PYROMETER, 0 -1600c 5843 $103.64
2-5/8" FUEL PRESS, 0-100 5863 $214.22
2-5/8" BOOST-VAC, 30 IN. 5877 $191.33
http://www.prostreetonline.com...auges
Old Feb 19, 2004 | 07:03 PM
VTi NA's Avatar
Default Re: Autometer Phantom Gauges (prostreetonline)
What color do these light up in? Is it green?
Old Feb 20, 2004 | 01:29 PM
Finest's Avatar
Default Re: Autometer Phantom Gauges (STi NA)
It's a longshot, but can you get just the SENSOR for the water temp gauge? Mine kinda "melted" after a week of driving. I tapped it into the top radiator hose neck on the head.
Old Feb 22, 2004 | 12:51 PM
E46M3CB's Avatar
Default Re: Autometer Phantom Gauges (98CTRCoupe)
interested in only the oil pressure sensor... can u get that? if so how much?
Old Feb 23, 2004 | 10:07 AM
2241 - 80 psi electric oil pressure sender - 29 bux
2242 - 100 psi electric oil pressure sender - 31 bux
If you have mechanical, let me know. its a different part number
Order here:
https://www.prostreetonline.com/pso/cgi/order.asp
Old Feb 25, 2004 | 06:16 PM
Tank8677's Avatar
hey wassup, i need some prices on the gauges.
1st-electrical oil pressure 0-100 psi,
2nd-electrical oil temp 100-250 degrees,
3rd-air/fuel ratio gauge,
last is the gauge pillar pod for 92 civic hatch.
thank you very much
fishieman
Dec 10, 2008 10:43 PM
Forrest Gump 9
Apr 27, 2004 09:18 PM
egg
Aug 6, 2003 07:11 PM
1.8T_EG
Jul 20, 2003 03:15 PM
Boostless97Lude
Jun 18, 2003 08:42 AM
