... gauges for turbo application (searched)...
Old Jul 20, 2003 | 02:51 AM
1.8T_EG's Avatar
Default ... gauges for turbo application (searched)...
... first off, i searched and found most everyone runs/recommends:
boost
egt
oil pressure
... personally, i will be running:
boost
wb02
oil pressure
... my question, what is the next most important gauge?...
fuel pressure?
oil temp?
amp / volt meter?
other?
... lemme know... thanks...
*edit* - typos
Modified by 1.8T_EG at 4:35 PM 7/20/2003
Old Jul 20, 2003 | 06:33 AM
Dee's Avatar
Dee
Default Re: ... gauges for turbo application (searched)... (1.8T_EG)
Boost
EGT
WB02
Fuel psi
Those are necessary for tuning. EGT reacts faster than AFR but the combo of both will allow you to tune without any guesstimation. From there I would go Oil psi, water temp and then oil temp.
Instead of running a billion gauges I wil be running a single Defi display that will show EGT, Boost and fuel psi along with a TE WB02 Version 1.5. Eventually I will add sensors for oil pis/temp and water temp to the Defi control box.
Old Jul 20, 2003 | 12:40 PM
1.8T_EG's Avatar
Default Re: ... gauges for turbo application (Dee)
... thanks for the input... anyone else?
Old Jul 20, 2003 | 01:09 PM
twkdCD595's Avatar
Default Re: ... gauges for turbo application (1.8T_EG)
boost
egt
oil pressure
wb02
Old Jul 20, 2003 | 01:17 PM
vtec.dc2's Avatar
what type of setup - mild/high boost - with/without standalone? i'm running boost/oil pressure and cheap a/f meter - all electronic, - my setup is mild boost with standalone..
i dont see the need for wideband unless you're tuning, unless you want to spend extra money - it doesn't hurt to have more gauges.
if your run fmu, i would also get fuel pressure. oil temp is something i would get later on, - if you check your ignition components often enough, you can do without it..
Old Jul 20, 2003 | 01:34 PM
1.8T_EG's Avatar
Default Re: ... gauges for turbo application (vtec.dc2)
... setup will be on the hack at 9-10 psi until winter... then hondata and 15-20 psi... as for the wideband, i have techedge and will be using it instead of an egt... thanks for info... i am starting to think i might not need any other gauges... anyone else?
Old Jul 20, 2003 | 02:59 PM
GSRswapandslow
Guest
Posts: n/a
i think everyone should have a water temp gauge as well
they aren't that expensive, and they are SO MUCH MORE ACCURATE than that stock bullshit that either doesn't move or overheats.
Old Jul 20, 2003 | 03:15 PM
TRE_'s Avatar
i'm running:
boost
EGT
water temp
fuel pressure
i'd like to get a wb02 down the road, but for now the gauges I have are very helpful IMO.
VTEC+Mini
May 27, 2012 12:42 PM
fishieman
Dec 10, 2008 10:43 PM
no bull
Oct 2, 2007 11:34 AM
94typeR
Apr 30, 2007 02:05 PM
Boostless97Lude
Jun 18, 2003 08:42 AM
