what guages are everyone running
Old Jun 17, 2003 | 07:58 AM
Boostless97Lude
Guest
Posts: n/a
Default what guages are everyone running
not a brand, just what are you monitoring, EGT, AIT oil temp, oil pressure etc.
i've only got boost and oil pressure, plus a wideband display, i am thinking of adding AIT, EGT, water temp, oil temp
Old Jun 17, 2003 | 08:00 AM
ReVtecSi's Avatar
Default Re: what guages are everyone running (Boosted97Lude)
i got greddy a/f, egt, and boost......thinkin of getting one more
Old Jun 17, 2003 | 09:39 AM
redline201's Avatar
Default Re: what guages are everyone running (ReVtecSi)
autometer boost and egt
gonna get a oil pressure ASAP
Old Jun 17, 2003 | 10:05 AM
GreddySi99's Avatar
Default Re: what guages are everyone running (redline201)
boost, EGT, A/F, air intake temp, knock, fuel pressure and thats all folks
Old Jun 17, 2003 | 10:14 AM
B18c1turboedEK's Avatar
Default Re: what guages are everyone running (intercooledJRSC)
Turbo,oil,exaust temp,,water,air fuel,N20.....I love watching my motor work.
Also have Intake temp does anyone know how to hook up a mechanical one?
symba's Avatar
my plans are for: boost, oil press, fuel pressure in pillar pod and then oil temp, EGT in the center console
Old Jun 17, 2003 | 10:15 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: what guages are everyone running (symba)
Defi Link
Boost
Oil Pres
Fuel Pres
EGT
Old Jun 17, 2003 | 10:17 AM
WHats EGT ??
Old Jun 17, 2003 | 10:28 AM
XDEep's Avatar
Default Re: what guages are everyone running (Koticcivic4u)
egt- exhaust gas temp
i plan on boost, oil pressure, egt, and afr (wb) for the essentials. amperage and water temp i already got for cheap.
Old Jun 17, 2003 | 10:33 AM
turbochic's Avatar
Default Re: what guages are everyone running (XDEep)
I have water temp, oil temp, boost, air/fuel.
Old Jun 17, 2003 | 10:34 AM
MachAF's Avatar
Default Re: what guages are everyone running (fmaxturbochic)
boost and EGT
Old Jun 17, 2003 | 10:36 AM
ladysman's Avatar
Default Re: what guages are everyone running (MachAF)
boost, egt, oil pressure, wideband O2 display
Old Jun 17, 2003 | 01:39 PM
boosted3g's Avatar
Default Re: what guages are everyone running (ladysman)
Autometer ultralites- Tach, boost pressure, oil and water temps, FJO display.
All electronic except for the boost pressure.
Old Jun 17, 2003 | 02:19 PM
BROOD's Avatar
Boost, EGT, ECT, EOP, Fuel Pressure, WideBand display, and Volts
(a mixture of Greddy, TechEdge, and Blitz)
Old Jun 17, 2003 | 09:52 PM
XDEep's Avatar
Default Re: what guages are everyone running (SLPR)
whats ect and eop?
wouldnt you guys rather have oil pressure than oil temp? if you spring a leak your oil pressure immediately drops. your temp may not change much.. at least not until youre bone dry heh. both is good too, but id rather not have extra clutter. at least with water temps you know its supposed to be around 185F, and thats pretty much what every car uses.
Old Jun 17, 2003 | 10:25 PM
one more chance's Avatar
ive got an apexi avcr....i've had problems with autometer in the pass with inaccuaret boost readings...decided to fork out the extra $$$ for an electronic monitor.
Old Jun 18, 2003 | 04:09 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: what guages are everyone running (one more chance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one more chance &raquo;</TD></TR><TR><TD CLASS="quote">ive got an apexi avcr....i've had problems with autometer in the pass with inaccuaret boost readings...decided to fork out the extra $$$ for an electronic monitor. </TD></TR></TABLE>
yeah, my AEM EMS is a boost controller, i am not about to spend $400 just to monitor boost
Old Jun 18, 2003 | 04:45 AM
evoeone's Avatar
autometer boost and egt, i wouldnt put the probe in the mani again tho cause it runs out of scale on the gauge, pretty much any gauges are ok, once your tuned you get a bench mark from the gauges you got, theres no gauge like a wideband
Old Jun 18, 2003 | 06:46 AM
LJR-LUDE01's Avatar
defi link boost, techedage 02 display at the moment. I have a egt but not install
Old Jun 18, 2003 | 06:54 AM
DirtyLude's Avatar
Default Re: (LJR-LUDE01)
I've got rid of most of mine. I have wideband and J&S monitor left. I have the AVC-R if I want to check to make sure boost is going where I want it, but it's in the glovebox.
The police are really tight around here, so I got rid of my a-pillar pod and my Defi HUD gauge.
Old Jun 18, 2003 | 07:20 AM
BROOD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XDEep &raquo;</TD></TR><TR><TD CLASS="quote">whats ect and eop?</TD></TR></TABLE>
ECT = engine coolant temp
EOP = engine oil pressure
EOT = engine oil temp
If you spend too much time diagnosing engines and you will find yourself using more and more shortcut terms for sensors. Sorry for the confusion.
Old Jun 18, 2003 | 08:08 AM
JM Performance's Avatar
honostly i never look at any of them. i could probably survive w/ none....
Old Jun 18, 2003 | 08:35 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: what guages are everyone running (00SilverLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00SilverLS &raquo;</TD></TR><TR><TD CLASS="quote">honostly i never look at any of them. i could probably survive w/ none....</TD></TR></TABLE>
it's when you have none and something goes wrong when you say "damn, i shoulda had a guage for that"
Old Jun 18, 2003 | 08:38 AM
DirtyLude's Avatar
Too many gauges is just a nuisance. Your not watching them. The likelyhood of catching something like an oil pressure drop before it's a real problem is low.
A single warning light with warning switches is a better alternative for a daily driver.
Old Jun 18, 2003 | 08:42 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: what guages are everyone running (DirtyLude)
i'm gonna run it in SoloI on the road track, lots of guages will be a good idea
VTEC+Mini
May 27, 2012 12:42 PM
fishieman
Dec 10, 2008 10:43 PM
no bull
Oct 2, 2007 11:34 AM
s13freeaak
Jun 5, 2006 07:07 PM
1.8T_EG
Jul 20, 2003 03:15 PM
