Lighting HID/Xenon kits, Retrofits and Associated Topics
Need help with electrical problem for lighting
Old Oct 12, 2007 | 03:00 PM
sublimnal's Avatar
Default Need help with electrical problem for lighting
So recently , i would say last week, my car running lights( corner lights , cluster meter lights, illumination for the dash and tailights dont' work
on the toggle switch for the light my 2nd click doesn't' work .
but wheni click it all the way my headlights still turn on .
The cluster icons for everything work but the cluster doesnt' illuminate.
the click works
the headlight , low beams and high beams work
my turn signals work it i use them , ex HAZARDS
but my tails lights are all shot unless i press the brake lights .
someone please help me
i dont know whats wrong
i have changed al the fuses and they are all fine.
here is a picture of my integra ,
Old Oct 16, 2007 | 11:33 AM
sublimnal's Avatar
Default Re: Need help with electrical problem for lighting (sublimnal)
lil help
Old Oct 16, 2007 | 01:46 PM
CarbonizedDX's Avatar
Check #20 or
Check your under hood fuse box and check fuse #32
Old Oct 16, 2007 | 05:15 PM
sublimnal's Avatar
thanks , will do
Old Oct 17, 2007 | 11:50 AM
CooBreeze's Avatar
Default Re: (sublimnal)
I own a 91 Honda Accord LX 4dr and am having the same problem. I noticed a frying sound one time under the console. Is there a Relay switch that could have gone out.
I've checked every fuse even swaped one of the light relays under the hood. Still nothing.
It getting dark outside during the morning and soon the evenings will be dark also. I really don't want a ticket. HELP!!!!
Old Oct 18, 2007 | 07:17 AM
CooBreeze's Avatar
Default Re: (CooBreeze)
Not sure since Im no car expert, but last nite on my way home my cars idle droped to a point where I had to stay on the gas to keep it running. A few months back I installed a new Main Relay switch, but since I didn't have the proper tools I left the old one in, and hooked up the new one but did not mount it.
Now I'm thinking that the reason is because, attatched is a metal mount witch probaly acts as a ground right?
So im thinking thats probaly why its sizzling out on me. I'm going to unhook the new one and reinstall the old. If this fixes my problem, Im positive thats what is causing your problem also. I'll let you know.
Modified by CooBreeze at 9:25 AM 10/18/2007
Old Oct 18, 2007 | 12:16 PM
sublimnal's Avatar
will try
Old Oct 19, 2007 | 06:51 AM
CooBreeze's Avatar
Well I was wrong its not the main Relay switch. The main relay controls the fuel pump in your gas tank. Looks like im gonna take it in to get fixed
Old Oct 19, 2007 | 01:33 PM
sublimnal's Avatar
ok thanks
Old Oct 19, 2007 | 02:44 PM
CooBreeze's Avatar
I made a apointment for Tuesday so by Wednesday I should have a solution to the problem at my expense
Old Oct 20, 2007 | 11:52 AM
sublimnal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooBreeze &raquo;</TD></TR><TR><TD CLASS="quote">I made a apointment for Tuesday so by Wednesday I should have a solution to the problem at my expense </TD></TR></TABLE>
thanks but i know whats wrong , if that doesnt' work i'll be back bumping this thread lol .
=D
Old Oct 22, 2007 | 10:59 AM
CooBreeze's Avatar
What do you think it is? I'd much rather save the money and do it my self.
Old Oct 22, 2007 | 11:50 AM
sublimnal's Avatar
i think i found a wires that was grounding out, but i won't have time til today to do it,
i'll keep everyoe updated ,
thanks guys
Old Oct 22, 2007 | 01:35 PM
CooBreeze's Avatar
You might be on to something! Considering I noticed at first when I would turn on my running lights in the morning they would'nt come on at frist. Sometimes you would hear a spark or two. Then they would come on. Just under the steering console.
Let me know!
Old Oct 22, 2007 | 04:17 PM
CooBreeze's Avatar
Well I hate it when I'm right. I just got a call from Honda, they fixed my problem.
It was a Relay Switch! Headlight Relay he called it. $30 dollar part cost me 400 bucks!!!!!!!
Guess I'll go pick up my car Drop my pants in the lobby and say I'M REDY B#(%S!!!!!!!
Here is a list of prices for that part.
http://www.rockauto.com/catalo...,4472
I just wish I knew that that was a relay switch in its own.
Any way my problem is solved hope this helps bud.........
-CooBreeze
Modified by CooBreeze at 5:30 PM 10/22/2007
Modified by CooBreeze at 5:31 PM 10/22/2007
Modified by CooBreeze at 5:32 PM 10/22/2007
Modified by CooBreeze at 5:35 PM 10/22/2007
Old Oct 23, 2007 | 01:18 PM
sublimnal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooBreeze &raquo;</TD></TR><TR><TD CLASS="quote">Well I hate it when I'm right. I just got a call from Honda, they fixed my problem.
i changed the part 3 times already and it wasnt' that for me
-CooBreeze
Modified by CooBreeze at 5:35 PM 10/22/2007</TD></TR></TABLE>
Old Oct 24, 2007 | 12:42 PM
sublimnal's Avatar
i have tried this for my car, no mas
sublimnal
Oct 25, 2007 05:04 PM
sublimnal
Oct 12, 2007 07:09 PM
looxs
11
Feb 5, 2007 04:06 PM
4G63T
Feb 3, 2006 09:51 AM
InJ3cted
Jun 26, 2005 09:18 AM
