Need help with electrical problem for lighting
Old Oct 12, 2007 | 02:58 PM
sublimnal's Avatar
Default Need help with electrical problem for lighting
So recently , i would say last week, my car running lights( corner lights , cluster meter lights, illumination for the dash and tailights dont' work
on the toggle switch for the light my 2nd click doesn't' work .
but wheni click it all the way my headlights still turn on .
The cluster icons for everything work but the cluster doesnt' illuminate.
the click works
the headlight , low beams and high beams work
my turn signals work it i use them , ex HAZARDS
but my tails lights are all shot unless i press the brake lights .
someone please help me
i dont know whats wrong
i have changed al the fuses and they are all fine.
here is a picture of my i integra , i just got it out of the shop to prove ths is for the itr forum.
Old Oct 12, 2007 | 03:23 PM
ITR_HO's Avatar
Default Re: Need help with electrical problem for lighting (sublimnal)
have you messed with your dash harness?
i had a similar issue before and it ended up being my ECU. it went bad some how. when i turned on the car it was fine but as soon as i turned on the lights they would dim then go bright again repeatedly. that goes for all the lights, dash, signals and ETC.
Old Oct 12, 2007 | 05:33 PM
SuckMyDOHC's Avatar
I fixed the same exact problem in my friends EG. All of those lights are running off of the same circuit. One of his corner lamps wiring was stripped and grounding out so I taped up the wire, replaced the fuse, and he was good to go. Double check all your wiring around your lamps. Easiest thing to check first other than the fuse
Old Oct 12, 2007 | 06:53 PM
sublimnal's Avatar
Default Re: (SuckMyDOHC)
thanks i'll check that out .,
Old Oct 12, 2007 | 07:09 PM
SuckMyDOHC's Avatar
hey wait do you work at F1?
sublimnal
Oct 25, 2007 05:04 PM
sublimnal
Lighting
16
Oct 24, 2007 12:42 PM
4G63T
Feb 3, 2006 09:51 AM
InJ3cted
Jun 26, 2005 09:18 AM
nortel
Aug 25, 2004 06:50 AM
