Lighting HID/Xenon kits, Retrofits and Associated Topics
Civic HIDS
Old 04-14-2014, 06:02 AM
rawrxdino8's Avatar
Icon3 Civic HIDS
I put HIDS' im my car about a month ago. They worked fine ever sense then. Last night I went to go take it for a drive and they shut off. I replaced the fuse the blew and tried, then worked for about 2 seconds. I checked the fuse and it was fine but replaced it about 3 more times to see if it was bad. Now lights still don't work. Any ideas what to try or look for. I gave a quick glance around the wires to see if any are cut open and couldn't find anything.!
Old 04-14-2014, 10:21 AM
moderator emeritus
98vtec's Avatar
Default Re: Civic HIDS
moved to correct section
Old 06-02-2014, 04:32 PM
D16terror's Avatar
Sounds like your ballast box went out. But you could use your voltmeter to see if you 12 volts and ground at your headlight harness. Just a suggestion
Kellybaraka
02-11-2016 08:55 PM
Crono139
Lighting
01-02-2009 08:03 AM
TehMan
04-03-2008 10:12 AM
LudeJdm
Lighting
11-27-2007 04:37 PM
Shaun
13
06-14-2003 03:03 PM
Quick Reply: Civic HIDS
