Steve
Old Jul 20, 2015 | 05:16 AM
cabrito911's Avatar
Default Steve
Hi everybody!
Old Jul 20, 2015 | 05:38 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Steve
whudupppp steve
Old Jul 20, 2015 | 05:42 AM
cabrito911's Avatar
Default Re: Steve
Originally Posted by 09chaplak
whudupppp steve
cabrito911's Avatar
Default Re: Steve
Not much! My car has me on the blitz! Lol
Old Jul 20, 2015 | 07:47 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Steve
whatchu got?
Old Jul 20, 2015 | 07:50 AM
cabrito911's Avatar
Default Re: Steve
I got a 99 ek 4dr with a 95 d15 I put in it. I got the jumper harness and p28 ecu and no spark.
Old Jul 20, 2015 | 07:52 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Steve
What did you bring over with the swap, other than the engine? Did you keep anything OBD2?
Old Jul 20, 2015 | 07:58 AM
cabrito911's Avatar
Default Re: Steve
That's all I brought! I'm using a p28 ecu jumped from obd2 to obd1
Old Jul 20, 2015 | 07:59 AM
cabrito911's Avatar
Default Re: Steve
Then I found out the distrubutor was different so I changed all the insides from to the other!
Old Jul 20, 2015 | 08:19 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Steve
Are you getting any CEL's? How did you verify that you weren't getting spark?
Is your ECU chipped? You need to run a P06 map, not the P28.
Old Jul 20, 2015 | 08:51 AM
cabrito911's Avatar
Default Re: Steve
I took out all the spark plugs to see if there's spark
Old Jul 20, 2015 | 08:59 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Steve
Did you ground the plugs while testing them? You could've fried the coil if you just left them open and tried cranking the engine over to test for spark.
But the bigger issue is the ecu, you need a P06 for a d15b7, not the P28. A virgin P28 is for a D16z6 or if it's chipped you can burn multiple maps for various applications.
Old Jul 20, 2015 | 09:02 AM
cabrito911's Avatar
Default Re: Steve
I got a d15b jdm motor. I need a po6! What car does that come from?
Old Jul 20, 2015 | 09:20 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Steve
JDM D15B actually is the P08, thought it was the b7. But the P28 should actually work there. Test your coil, you probably fried it when testing for spark. Just keep going back until you find where the power stops. You went to the plugs, and there was nothing. You may have fried the coil but regardless, now check the coil for spark. Anything? A car needs 4 things to run, fuel spark, compression and air. Make sure you're getting all of them.
Old Jul 20, 2015 | 09:22 AM
cabrito911's Avatar
Default Re: Steve
The way I check for spark is I take all the plugs out and wire and put the plug back in the wire and ground them.
Old Jul 20, 2015 | 09:25 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Steve
Test the coil for spark now, as long as you grounded the plugs you will be fine.
Old Jul 20, 2015 | 12:30 PM
EG9_Sedan's Avatar
Default Re: Steve
sup
vietelement
Texas -OK -LA (Sales)
May 7, 2010 03:56 PM
2kgsrt
Oct 2, 2009 03:35 PM
EH6TunerDaniel
14
Mar 6, 2007 11:44 AM
CroSi
Dec 9, 2003 10:39 AM
JOEY F.
Jul 23, 2003 01:28 PM
