MAP sensor in two different places
Old Sep 6, 2011 | 01:01 AM
moemoney's Avatar
Default MAP sensor in two different places
I just swapped a b18c into my 1992 acura integra gsr ( originally b17 vtec ). I recently bought a new throttle body, but noticed that the MAP sensor for the original motor setup is located on the firewall. this is a problem because there is a spot to install a MAP sensor on the throttle body that i bought (because the map sensor on the b18c motor is not located on the firewall but the TB itself)
what do I do? do I extend the wires from the one on the firewall ? and what do I do with the hose connected to the MAP sensor on the firewall?
if I lost you, please tell me and ill clarify
thanks everyone
moe
Old Sep 6, 2011 | 05:02 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: MAP sensor in two different places
I'd use the one on the throttle body and remove the one on the firewall.
Old Sep 6, 2011 | 08:41 AM
moemoney's Avatar
thanks for the reply... so would i just ignore the whole apparatus of the one on the firewall? do i need to make any connections other then the plug that i might have to extend.
thanks again
Old Sep 6, 2011 | 09:07 AM
Dogginator's Avatar
Daisy... Daisy...
What wiring harness are you using?
Old Sep 6, 2011 | 10:19 AM
moemoney's Avatar
using the one for the b17 original motor. (92 GSR motor )
Old Sep 6, 2011 | 10:22 AM
Dogginator's Avatar
Daisy... Daisy...
I assume that the ECU is a P72 from the B18C. Is the harness plug the same for both MAP sensors?
Old Sep 6, 2011 | 10:39 AM
moemoney's Avatar
sont have the other MAP sensor just yet, I wanted to know if i need it before i spend the money. i can search up if its the same.
Old Sep 6, 2011 | 10:55 AM
Dogginator's Avatar
Daisy... Daisy...
I'm not sure how you would block off the MAP sensor hole on the throttle body. You either need the other throttle body (B17 style) or the MAP sensor for the B18C1 throttle body.
Old Sep 6, 2011 | 01:10 PM
sc34dc4's Avatar
KMS sells a map block off plate. Can be picked up for $20 I have one since I'm running a gm 3 bar. Or just pick up a map sensor from and honda that mounts it on the throttle body and use it to plug the hole. Make sure you have the o ring or it will leak.
Old Sep 6, 2011 | 09:23 PM
moemoney's Avatar
thanks guys ,,, but where would i install the vacuume hose that is originally attached to the b17 throttle body? because I will block the MAP sensor postion on the b18c TB there will be no slot to put the other MAP sensors hose. I will upload pictures and show u guys ....
Old Sep 6, 2011 | 09:26 PM
moemoney's Avatar
are you selling yours? i looked for the site to buy it but i couldnt find it. can u send me a link ?
Old Sep 6, 2011 | 10:26 PM
sc34dc4's Avatar
Originally Posted by moemoney
thanks guys ,,, but where would i install the vacuum hose that is originally attached to the b17 throttle body? because I will block the MAP sensor position on the b18c TB there will be no slot to put the other MAP sensors hose. I will upload pictures and show u guys ....
The easiest thing to do is put your b17 throttle body on the gsr motor and there you will have your hook up for your vacuum line and won't need to buy anything. It's a plug and play affair since you're using the b17 engine harness.
No I am not. Kms engine development out of Georgia "google"
Old Sep 7, 2011 | 10:33 AM
moemoney's Avatar
so i cant use the b18 edelbrock TB i bought eh? theres no way? unless i change the harness?
MoeMoney1984
Jun 14, 2014 04:41 PM
nuginu
K Series
Aug 17, 2013 11:26 AM
moemoney
Aug 25, 2011 12:19 AM
SVOboy
Mar 26, 2006 11:48 AM
civichatch67
Sep 21, 2005 10:11 AM
