What mounts for B-series in EK
Old 05-07-2005, 01:14 AM
dc2drifterx's Avatar
Default What mounts for B-series in EK
Just wanting some clarification of what mounts you need to swap a b-series into a EK. Thanks
Old 05-07-2005, 01:17 AM
SkRiBLaH's Avatar
Default Re: What mounts for B-series in EK (dc2drifterx)
i know for sure you use the 99-00 EM1 rear tranny bracket
as far as drivers side i think the d series will work? someone please correct me, i would also like to know.
and also can you use the d series post for b series?
Old 05-07-2005, 01:33 AM
AL_EK's Avatar
All you would need is the 99-00 si rear mount and bracket. You can use the regular dx driver side mount but i suggest to upgrade it because it will be the first mount that will go out on you. I would suggest get the place racing driver side mount or better get the hasport mount kit
Old 05-07-2005, 07:22 AM
JdmLub's Avatar
Default Re: What mounts for B-series in EK (AL_EK)
go to hasport and look around that is what i did
Old 05-07-2005, 07:46 AM
ReDHaTcHyGuy's Avatar
Default Re: What mounts for B-series in EK (JdmLub)
u can us the stock mounts but u need the rear triangle mount and the hard block mount from a a 99-00 Si, I would suggest getting a set of hasport mounts since the stock mounts are a little soft.....
Old 05-07-2005, 05:17 PM
SkRiBLaH's Avatar
Default Re: What mounts for B-series in EK (ReDHaTcHy97)
hard block mount? do you mean post?
Old 05-07-2005, 05:43 PM
Status Sean's Avatar
Default Re: What mounts for B-series in EK (SkRiBLaH)
if u are gonna swap a b series in a EK u need either a gsr, or SI rear mount, and u can use your sohc mounts on the side and i would use the integra ones that mount to the front of the block and the front of the tranny !
Old 05-07-2005, 05:47 PM
The Internet Tough Guy's Avatar
Default Re: What mounts for B-series in EK (rw92civic)
this is what you need i'm 100% sure.
99-00 Si Rear Tranny Mount bracket: 50827-s04-n10
99-00 Si Driver Side mount bracket: 11910-p30-000
#7 & (the other part is not numbered on this picture .. but it's right next to e14-1)
oh yeah
if you're going to keep AC, you need this
96 del Sol VTEC AC bracket: 38930-P54-000
#1 in the picture
Old 05-07-2005, 05:56 PM
Great guys, thanks for the clarification
Old 05-07-2005, 06:20 PM
xEnderx's Avatar
Default Re: (dc2drifterx)
Snap....great post Tough Guy.
Old 05-07-2005, 07:41 PM
BlueIntegraBoy's Avatar
To confirm, you need the rear "T" bracket and the driverside block mount. Everything else you can use from your Civic.
Old 05-07-2005, 11:01 PM
Default Re: What mounts for B-series in EK (BlueIntegraBoy)
yeah u can't use a integra rear mount, only the 99-00 Si, and the block mount i was talking about is the cast peice bolted to the driver side of the motor that has the stud's in it
Old 05-07-2005, 11:14 PM
oneforce's Avatar
correction, u need 99-00 si rear mount or one off of a honda crv, which ever one u can find..
Old 05-07-2005, 11:17 PM
JDMlyfestyle's Avatar
all you had to do was search. i did a write up a while back on swaps.
https://honda-tech.com/zerothread?id=983454
Old 05-08-2005, 03:55 PM
SkRiBLaH's Avatar
Default Re: (JDMlyfestyle)
that does not help when talking about EKs.
Old 05-08-2005, 04:28 PM
Ej6B20's Avatar
what about the front tranny bracket? I thought you had to use the one your tranny is from
Old 05-08-2005, 04:33 PM
westcoast1's Avatar
Default Re: (Ej6B20)
I have the hasport kit on my ek that is the bomb!!!
Old 05-08-2005, 05:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6B20 &raquo;</TD></TR><TR><TD CLASS="quote">what about the front tranny bracket? I thought you had to use the one your tranny is from</TD></TR></TABLE>
nope you use the one for the B series tranny.
Old 05-09-2005, 12:15 PM
YZFR6's Avatar
We have a 5 piece mount kit that drops your motor right in. It replaces the driver side mount too with a much stronger one. All Billet Aluminum.
d1nki
12-29-2013 03:20 PM
boostcrx91
05-09-2007 09:35 PM
Malakai
07-14-2006 05:02 PM
SyDuck
01-28-2005 06:59 PM
Norcalstoppy
09-25-2003 10:16 AM
Quick Reply: What mounts for B-series in EK
