What to look for in an engine swap?
Going to check a gsr swap either t/m or monday and was wondering what should I look for? Like is there anything I should check to see if anything is wrong? Said it has about 90k miles and had no codes before it was pulled. Forgot what year though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">oil leaks, sludge under the cap, cleanliness.</TD></TR></TABLE>
I'll probably just take the valve cover off then. Is there anything else?
Not doubting the seller just a precaution
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW »</TD></TR><TR><TD CLASS="quote">
I prefer to test drive a motor before i buy it. that way you know how it runs lately ive been seeing alot of people offering this as well
</TD></TR></TABLE>I prefer to test drive a motor before i buy it. that way you know how it runs lately ive been seeing alot of people offering this as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">I prefer to test drive a motor before i buy it. that way you know how it runs lately ive been seeing alot of people offering this as well</TD></TR></TABLE>
That's thing why I'm asking, it's already been pulled out. If it was still in the car I could so the usuall compression and leak down tests.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">as long as the tranny and starter are still you there, you can do a compression test.</TD></TR></TABLE>
How do you do that?
How do you do that?
take a jump pack to the engine, obviously remove the plugs,
hook the red up to the post on the starter, and the negative anywhere metal on the engine. if you have a remote start switch, run that from the red to the flat spade terminal on the starter. push the button, crank away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">take a jump pack to the engine, obviously remove the plugs,
hook the red up to the post on the starter, and the negative anywhere metal on the engine. if you have a remote start switch, run that from the red to the flat spade terminal on the starter. push the button, crank away. </TD></TR></TABLE>
alright thanks
alright thanks
check that the wiring harness is in tact.... make sure the fans are functioning, overheating has never been my friend
thermo switches and wires in tact... um if vtec engages lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg Yolk »</TD></TR><TR><TD CLASS="quote">check that the wiring harness is in tact.... make sure the fans are functioning, overheating has never been my friend
thermo switches and wires in tact... um if vtec engages lol</TD></TR></TABLE>
Well I'm using my si harness anyways, but he said the gsr one is there also.
thermo switches and wires in tact... um if vtec engages lol</TD></TR></TABLE>Well I'm using my si harness anyways, but he said the gsr one is there also.
DOHC Kid
51
Jun 13, 2008 10:29 AM
