What to look for in an engine swap?
Old Jun 17, 2006 | 08:49 PM
DFW's Avatar
DFW
Default What to look for in an engine swap?
Going to check a gsr swap either t/m or monday and was wondering what should I look for? Like is there anything I should check to see if anything is wrong? Said it has about 90k miles and had no codes before it was pulled. Forgot what year though.
Old Jun 17, 2006 | 08:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What to look for in an engine swap? (DFW)
oil leaks, sludge under the cap, cleanliness.
Old Jun 17, 2006 | 08:59 PM
DFW's Avatar
DFW
Default Re: What to look for in an engine swap? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">oil leaks, sludge under the cap, cleanliness.</TD></TR></TABLE>
I'll probably just take the valve cover off then. Is there anything else?
Not doubting the seller just a precaution
Old Jun 17, 2006 | 09:00 PM
JDMlyfestyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">
Not doubting the seller just a precaution </TD></TR></TABLE>
I prefer to test drive a motor before i buy it. that way you know how it runs lately ive been seeing alot of people offering this as well
Old Jun 17, 2006 | 09:01 PM
DFW's Avatar
DFW
Default Re: What to look for in an engine swap? (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">I prefer to test drive a motor before i buy it. that way you know how it runs lately ive been seeing alot of people offering this as well</TD></TR></TABLE>
That's thing why I'm asking, it's already been pulled out. If it was still in the car I could so the usuall compression and leak down tests.
Old Jun 17, 2006 | 09:04 PM
Mr. Badwrench
as long as the tranny and starter are still you there, you can do a compression test.
Old Jun 17, 2006 | 09:05 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">as long as the tranny and starter are still you there, you can do a compression test.</TD></TR></TABLE>
How do you do that?
Old Jun 17, 2006 | 09:10 PM
Mr. Badwrench
take a jump pack to the engine, obviously remove the plugs,
hook the red up to the post on the starter, and the negative anywhere metal on the engine. if you have a remote start switch, run that from the red to the flat spade terminal on the starter. push the button, crank away.
Old Jun 17, 2006 | 09:43 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">take a jump pack to the engine, obviously remove the plugs,
hook the red up to the post on the starter, and the negative anywhere metal on the engine. if you have a remote start switch, run that from the red to the flat spade terminal on the starter. push the button, crank away. </TD></TR></TABLE>
alright thanks
Old Jun 17, 2006 | 09:47 PM
egyolk's Avatar
check that the wiring harness is in tact.... make sure the fans are functioning, overheating has never been my friend thermo switches and wires in tact... um if vtec engages lol
Old Jun 17, 2006 | 09:50 PM
DFW's Avatar
DFW
Default Re: What to look for in an engine swap? (Eg Yolk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg Yolk &raquo;</TD></TR><TR><TD CLASS="quote">check that the wiring harness is in tact.... make sure the fans are functioning, overheating has never been my friend thermo switches and wires in tact... um if vtec engages lol</TD></TR></TABLE>
Well I'm using my si harness anyways, but he said the gsr one is there also.
DOHC Kid
51
Jun 13, 2008 10:29 AM
dawrenn
Jul 22, 2005 11:19 AM
Bones Barry
Feb 8, 2005 07:17 PM
BoostedGSRBubble
Aug 12, 2003 12:58 AM
DK4200
May 3, 2003 08:02 PM
