Oil coming out of valve cover breather?
Old 08-11-2003, 06:02 PM
BoostedGSRBubble's Avatar
Default Oil coming out of valve cover breather?
I was going over my motor the other day and I noticed some oil in my head and injector directly below my breather. Is this b/c of the pcv system? Could i run a catch can off of it and then just put a breather on the other end? Can this really hurt anything.
Old 08-11-2003, 06:11 PM
TwistedHatch's Avatar
Default Re: Oil coming out of valve cover breather? (BoostedGSRBubble)
usually oil coming out of the breather means you have blowby........do a compression check........
Old 08-11-2003, 07:25 PM
Default Re: Oil coming out of valve cover breather? (TwistedHatch)
I did one about 3 weeks ago, 240's across the board, ill do another tomorrow.
Old 08-11-2003, 07:48 PM
Ok, am i looking at the reason for a catch can? If so, has the consensus of FI people agreed on where it goes/setup?
Old 08-11-2003, 07:50 PM
ScrapinSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedGSRBubble &raquo;</TD></TR><TR><TD CLASS="quote">I did one about 3 weeks ago, 240's across the board, ill do another tomorrow.</TD></TR></TABLE>
240?!???!? Whats your CR? Whats your setup?
Old 08-11-2003, 07:54 PM
New User
meanteg's Avatar
Default Re: Oil coming out of valve cover breather? (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">
240?!???!? Whats your CR? Whats your setup? </TD></TR></TABLE>
I don't understand either.
Old 08-11-2003, 08:08 PM
Default Re: Oil coming out of valve cover breather? (meanteg)
Jdm b18c 10.6:1 comp, same as usdm ITR. Does anybody have anything to say bad about running a hose between the valve cover and the intake pre-turbo w/ a catch can in between?
Old 08-11-2003, 09:09 PM
bxsi's Avatar
hehe i have the same problem with my breather, my compression is real good as well. I don't burn that much oil ethier; about half a quart every 800 miles. I just grew to ignore it, my car runs like a champ besides the breather thing. Just always check your oil every week or so to make sure. I run 20w50 and 9psi on a built motor btw. mine actually slightly smokes from the breather filter as well, the smoke is very faint but it smokes nevertheless.
Old 08-11-2003, 09:15 PM
Default Re: (bxsi)
Well, i think after abusing my eyes and reading some archived posts, im going to run an open system. Leaving the valve cover breather and pulling out my pcv and dumping it to the ground, and capping off the intake mani. IS there anybody other than greenpeace who would object to this?
Old 08-12-2003, 12:46 AM
Tofurky's Avatar
Default Re: (BoostedGSRBubble)
just don't do it at the track, don't think anyone would appreciate oil out there.
Old 08-12-2003, 12:58 AM
ScrapinSi's Avatar
Default Re: (Tofurky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tofurky &raquo;</TD></TR><TR><TD CLASS="quote">just don't do it at the track, don't think anyone would appreciate oil out there.</TD></TR></TABLE>
yeah... they get kinda pissy when you start dumping oil on the track....
patrick4588
04-28-2010 07:17 PM
HighRevn
01-21-2007 03:39 PM
Viorent Grip! EG
10-06-2005 10:10 AM
JDMbolo
09-17-2005 04:57 PM
igo4bmx
06-09-2005 07:17 AM
Quick Reply: Oil coming out of valve cover breather?
