Tranny problems: hard to shift, what's wrong?
Old Nov 23, 2002 | 08:25 AM
Brewer's Avatar
Default Tranny problems: hard to shift, what's wrong?
First off, I've got a '93 CX with a B16A3.
The problem just started yesterday. Didn't seem gradual, just all of the sudden. When driving the car it's very difficult to shift gears, almost like the clutch isn't fully disengaging. But I don't think the clutch is the problem, it appears to be working exactly as it should. What else could be wrong?
Thanks
Old Nov 23, 2002 | 10:45 AM
Jonathan_ED3's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (BrewerHatch)
slave cylinder possibly?
I was driving one day and suddenly my whole clutch system went kinda 'limp' and then everything got really hard to get into/out of etc..
Turned out to be the slave cylinder...$25 part from Napa.
HTH.
Old Nov 23, 2002 | 11:34 AM
Soku1kcivic's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (hot_EG)
well i had a del sol before i was messing with a ferrari ahah and suddenly my gears didnt go in my 3-5 didnt go in so i drove home with only 2 gears on the freeway ahah its should be the clutch that was my problem
Old Nov 25, 2002 | 10:29 AM
Kataku2K3's Avatar
Default Re: Tranny problems: hard to shift, what's wrong? (Soku1kcivic)
Definately check the slave cylinder for leaks... Make sure your clutch is disengaging all the way... If not maybe you're fork are bent or possibly the actuator....
Old Nov 25, 2002 | 10:33 AM
LshatchTurbo's Avatar
New User
Default Re: Tranny problems: hard to shift, what's wrong? (JDMspecEG6)
I had the same problem you had a while ago, it came to be that the two front torque mounts we shot completely. I replaced them with the ES motor mount inserts. A year later everything is still working great. Check that out to see if its the problem because if the engine is moving to much when u try to shift, it would make putting it in gear more difficult than normal. Good luck
flatblack-h22
Transmission & Drivetrain
Jan 18, 2009 05:12 AM
teg969
May 4, 2008 04:16 PM
hspoon
Nov 20, 2006 10:38 AM
asiangel
Dec 30, 2002 02:34 PM
asiangel
Dec 30, 2002 01:17 PM
