throttle cable B18c5 into EK
Old 02-05-2007, 01:52 PM
12345's Avatar
Default throttle cable B18c5 into EK
What throttle cable do I need for a B18c5 into 97 EK (CX)? Been searching and wound up with some conflicting answers. What is recommended? 99-00 SI or ITR throttle cable?
Old 02-06-2007, 11:43 AM
12345's Avatar
Default Re: throttle cable B18c5 into EK (12345)
bump
Old 02-06-2007, 08:38 PM
APCforthewin's Avatar
innovative makes a bracket for the d series cable to use on the itr i think. but i have a b18cr in my 99 ek, and i just fliped the factory itr bracket 180 degrees so only one hole lines up and it works perfectly.
Old 02-07-2007, 12:30 PM
SuckMyDOHC's Avatar
99-00 civic si
Old 02-07-2007, 01:43 PM
12345's Avatar
Default Re: throttle cable B18c5 into EK (APCforthewin)
So I can just use the stock throttle cable?? can anyone confirm this? thanks
Old 02-07-2007, 06:33 PM
1. you can use your factorty cable if you get the innovative bracket : http://www.innovativemounts.co...59510
2. you can flip your factory ITR bracket 180 degrees and use the d-series cable (its free and it works fine)
3. you can get a ITR or 99-00 si cable (about 30 bucks)http://www.inlinefour.com/oemintypthro.html
Old 02-07-2007, 09:42 PM
12345's Avatar
thanks for the info!
BC_Garage
37
02-09-2016 08:46 PM
ekBrad
07-22-2009 01:52 PM
boostincoupe
02-17-2007 04:41 PM
94double2
01-15-2007 10:19 AM
vtec25
12-25-2006 02:53 PM
Quick Reply: throttle cable B18c5 into EK
