Swaping Secrets???
Old Dec 21, 2002 | 07:05 PM
  #26
riceboy's Avatar
Default Re: Swaping Secrets??? (sslude)
oh yea, I always find it wasier to start with the tranny mount and move clockwise around the engine bay bolting up the mounts, if you get the tranny mount tight first, you can pivot the motor somewhat, making the others easier to line up.
and a torque wrench, torquing all bolts to spec prevents bolt heads breaking loose and thread destruction.
heli-coils can be your best friend, but you dont want them to be.
Old Dec 23, 2002 | 07:13 AM
  #27
95IntegraGSRAZ's Avatar
Default Re: Swaping Secrets??? (riceboy)
How high would you say Im going to need to lift my car inorder to get the engine out from underneth it? I still think im going to need to rent a engine hoist.....
Old Dec 23, 2002 | 11:22 AM
  #28
stevel's Avatar
Default Re: Swaping Secrets??? (civicvteckid)
An engine hoist would be ideal. But try this without it...put the car on jackstands (all 4 corners) as high as you can get the car safely, figure out how to drop the engine to the ground safely, the jack isn't a bad idea but be careful. This is where friends come in. Have them lift up the front end (take the front bumper off, gives more room to grab), should make it easier that the car is up off the group already and then pull the motor out the side of the car.
Old Dec 23, 2002 | 10:01 PM
  #29
pennies_hatchie's Avatar
Default Re: Swaping Secrets??? (stevel)
all you need is in here
http://www.c-speedracing.com/howto/b18cswap/swap.php
Old Dec 24, 2002 | 07:42 AM
  #30
Default Re: Swaping Secrets??? (pennies_hatchie)
Thank you, that site is jsut what I wanted!
Brockasaurus
17
Apr 4, 2011 02:23 PM
SpeedRacer420
Apr 23, 2010 03:10 PM
pkolaboy
Apr 12, 2008 11:54 AM
totsie7944
Feb 2, 2008 11:29 AM
notstreetlegal
Apr 10, 2007 09:34 AM
