Swap Part 2
Old Jan 6, 2002 | 01:04 AM
Kamin's Avatar
Default Swap Part 2
Ok onto my next problem.
after day one i must say its going very well but heres the new one
the ball joint on the LCA i think. what is the best way to remove this, i have a ball joint splitter but as i have never done this before i am unsure if i am doing it right. should i just pound the hell out of the tool untill it pops off? any help would be appreciated.
Old Jan 6, 2002 | 02:16 AM
SpeedracerS4's Avatar
Default Re: Swap Part 2 (KAMiN)
A big *** hammer will do the work, but watch out for what are you hitting though. A good hit to the LCA will do the work
Old Jan 6, 2002 | 05:38 AM
DragII's Avatar
25 Year Member
Default Re: Swap Part 2 (SpeedracerS4)
I couldn't get mine...so I said F it, and dropped the LCA instead...worked just fine in removing the axles.
Old Jan 6, 2002 | 09:42 AM
Kamin's Avatar
Default Re: Swap Part 2 (D2C)
ok day 2 begins
thanks for the help
Old Jan 6, 2002 | 10:07 AM
Xav H22EG8's Avatar
go to summit racing I think.. there is a ball joint seperator that is cool as hell.. instead of banging the **** out of it all you do is slide the tool into the joint and then tighten down a bolt that will cause a piece of metal to push the bolt up and out.... It's really great.. makes the banging effect less excruciating.
Old Jan 6, 2002 | 12:31 PM
Kamin's Avatar
Default Re: Swap Part 2 (Xav H22EG8)
haha too bad im swapping it today also, anyone know what these wires are for and what to do with them? very important about to drop new engine in.
are they the ones that plug into this?
that is located drivers side firewall.
Old Jan 9, 2002 | 03:00 AM
EF8SIR's Avatar
hey the best way to split the ball joint is DONT USE THE SPLITTER YOU WILLMOST LIKELY RUIN THE BALL JOINT!! so take a hammer and hit the right side of the arm that the fork bolts to, hit that a few times with a hammer the ball joint will loosen up and you can just pull it right out!! it works great!
EF8SIR
Old Jan 9, 2002 | 09:00 AM
Kamin's Avatar
Default Re: Swap Part 2 (EF8SIR)
hehe i took drags advice and took the whole LCA off
worked great
thank god we had an impact wrench.
Old Jan 9, 2002 | 10:18 AM
Beer's Avatar
use a breaker bar and "pry" between the balljoint and spindle
[Modified by gotswap, 11:18 AM 1/9/2002]
CRseXy
13
Jan 10, 2005 10:49 PM
tuphatt
11
Sep 15, 2004 12:10 AM
B18C_EJ8
Sep 14, 2004 09:32 PM
plaiskool
33
Aug 7, 2004 03:42 PM
ransack
34
Jun 12, 2003 10:50 PM
