Swap H2B!! HELP!!
Old 12-03-2013, 02:35 PM
HONDist's Avatar
Default Swap H2B!! HELP!!
Hello everyone, i would like do an H2B swap on my civic EG4, but im not sure which transmission to put in if i'll have the H23 PDE engine in it which has 200h.p. im thinking about S80, spec 96 or spec 98... The spec 96 is longer and 98 is shorter! I really need your advice.
Old 12-03-2013, 05:35 PM
2.3h2b's Avatar
Default Re: Swap H2B!! HELP!!
gejt jthe 4.7"98 spec" you will be much happier I have a 4.4 "b16"on mine was left wanting much shorter gears now Im getting a 4.9 FD but my f20b revs to 9k I'm matching my gearing with my power band I make power to 9k on the dyno.
Old 12-03-2013, 06:18 PM
HONDist's Avatar
What's the maximum speed you reach with pair of 4,9?
Old 12-05-2013, 03:36 PM
HONDist's Avatar
AP!
Old 12-05-2013, 04:04 PM
I am Jack's...
Tyler Dirden's Avatar
Just my opinion. H2b has a ton of torque compared to it's little bros. HP is nice too N/A. In a car like your EG, it's really gona pull well and deliver great street performance with the common 4.4FD. You will be fractionally increasing the FD with lower tires on your EG and unless your looking to go high 12s that motor stock will get you into the deep 13s well driven and set up. Full race, go spec R, mostly street go GSR box.
PS, the stock redline for those is like 8200rpm, going to 9000k does nothing on the dyno to a stock motor but throw it's life away.
I've got a H22 in my Accord (much heavier car) and it's a blast to drive even with the 4.4FD trans.
Old 12-05-2013, 04:35 PM
HONDist's Avatar
thank u bro! I been thinking that pair of 4.4 would be better for city, as well as for raicing !
Old 12-05-2013, 04:58 PM
HONDist's Avatar
Everything looks nice under ur hood! where did you hide all the wires? do you have more pictures of the motor to see how does wiring go there?
Old 12-06-2013, 10:53 AM
I am Jack's...
All of the wires go underneath the fender lip on the outter frame rail. the wires on the passenger side require a small hole to be drilled under the fuse/relay center to get around cleanly. There are dozens of ways to do a tuck as other threads can illustrate much better.
Sorry not much better detail than this shot down the passenger side.
Old 12-07-2013, 07:39 AM
2.3h2b's Avatar
I dont know yet its being installed right now but my 4.4 b16 does 128 mph in 4th gear at around 8900 rpms.For a h22/h23 a 4.4 is fine like the other guy said they rev to around 8k and around town the b16 is great.I only care about performance not about MPGs or anything else so I went all out.I'll PM you my youtube channel you can see my pro 2 cam'd f20b f2b eg
Old 12-07-2013, 07:44 AM
2.3h2b's Avatar
https://www.google.com/url?sa=t&rct=...EE5CVYGlhQyB4A
my build thread
KPowerSquadron
Transmission & Drivetrain
11-09-2010 03:09 PM
vla
09-02-2008 10:13 PM
Trench_Rat
04-28-2006 11:32 AM
DB8ITR
10-03-2005 12:18 PM
tvrsir
15
12-07-2003 08:19 AM
Quick Reply: Swap H2B!! HELP!!
