Stripped out head stud!!!
Old Sep 21, 2001 | 10:40 PM
vspec12's Avatar
New User
Default Stripped out head stud!!!
One of the studs stripped out the hole in my block completely. I was wondering if anyone has every had this problem and if it is recommended or possible to re-tap the hole and use a larger head stud. I don't know if thicker studs are available, and if they are do you guys think it will still fit through the head?
Old Sep 21, 2001 | 11:07 PM
Blown90hatcH's Avatar
Default Re: Stripped out head stud!!! (vspec12)
Head stud....as in the stud that bolts the head to the block or stud as in the bolt that bolts the header to the motor? The header bolt is an easy fix...but the other is a grip. Let me know which one it is.
Old Sep 21, 2001 | 11:15 PM
vspec12's Avatar
New User
Default Re: Stripped out head stud!!! (Blown90hatcH)
It's the stud that connects the head to the block
Old Sep 22, 2001 | 02:19 AM
C-speed's Avatar
You will have to use a Heli-coil to repair it. Easy fix.
Old Sep 23, 2001 | 07:51 AM
1.8EG-T's Avatar
Becareful, I did this once before, I took the block to a shop to be repaired and they literally jacked it all up, short story is I had to buy a new block. Part was my fault as I did not know the reputation of the shop, I had just moved to the area, short story for that, never let a redneck work on your Honda.
willard steen
Apr 5, 2016 12:22 AM
DC2-ProdUcTiOnS
Oct 27, 2011 02:07 PM
The93egg
Mar 1, 2009 11:02 AM
steven_highet
Jan 25, 2009 11:47 AM
Peter Brady onlyonweekndz
Dec 4, 2007 10:22 AM
