Stripped out block/head stud thread..
Old Jan 16, 2009 | 11:27 AM
steven_highet's Avatar
Default Stripped out block/head stud thread..
Well my dumbass stripped out one of my head stud blockthreads. Does anyone know of any fixes out there that i could use to fix my problem. Maybe like a M12x1.5 insert or something. Im sure someone has done this before and fixed it.
Old Jan 16, 2009 | 11:31 AM
redboost10's Avatar
Default Re: Stripped out block/head stud thread..
not a fix for your problem, more of a prevention: i replaced all the "bolts" with studs for the intake and exhaust manifold.
Old Jan 16, 2009 | 12:15 PM
2point1's Avatar
http://www.timesert.com/
Old Jan 16, 2009 | 01:01 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
hmm I'm not sure if I would trust a threaded insert on a head stud hole, seeing as you have to drill and tap the hole out larger to get the insert in there.
But then again I'm not sure how else it would be repaired, short of replacing the entire block.
Old Jan 16, 2009 | 01:27 PM
2point1's Avatar
trust me it works great.it's in my block now and has been in there for like two years. just got it rebuilt to with no problems at all
Old Jan 19, 2009 | 08:02 PM
spooledex's Avatar
did the same thing in my b20 vtec.. got a helicoil kit.. cost me like 300 cause my friend took out a headbolt with the impact. wasn't watching him.
Old Jan 19, 2009 | 08:35 PM
lightning's Avatar
Time-sert is the way to go for this. Helicoil would be used for less severe duty such as an exhaust manifold bolt or accessory bolt.
Old Jan 20, 2009 | 12:12 PM
92_civic's Avatar
timesert is the way to go...I bought the kit, have used it on a few turbo blocks making 400+ with no issues...and its a very easy repair using the timesert, as opposed to trying to helicoil it
Old Jan 25, 2009 | 11:47 AM
I will def go with the timesert kit. Anyone willing to rent me the kit and ill give you a deposit. I know the kit is like $400
Peter Brady onlyonweekndz
Dec 4, 2007 10:22 AM
80884
Dec 8, 2004 04:09 PM
V8 BAIT
Jul 1, 2004 01:18 PM
CTR-CRX
Mar 14, 2004 07:05 PM
vspec12
Sep 23, 2001 07:51 AM
