starting problems
car: 92 civic cx
engine: 92 b17 well, the swap was in for liek 3 weeks, everything went fine...today, the car doesnt turn over, we checked the starter, its fine. we checked the battery, thats fine. we checked to see if it was the clutch switch(no voltage at starter w/o pressing clutch, 12.xx voltage when clutch is pressed, thats correct right?) we tried applying direct current to the starter(wire from positive to both starter plugs), still doesnt turn over, anyone have any ideas? we were able to push start it and it ran |
Re: starting problems (VTECNLUDE)
So your starter works but it wont turn over when you turn the key?If so when you turn the key can you hear the starter?
Ignition switch?
Re: starting problems (J2turbo21)
nope, cant hear the starter turn or anything, and bout the ingition switch, wheres it at? how do I check it?
if your starter doesnt turn then how can you say starter is fine?
obvious if you hook up the starter directly to the 12 v battery and it doesnt do shit, your starter is broke. |
Re: starting problems (RoyFokker)
did you read my first post? I said I took out the starter, placed it on the ground, and connected wires fromt he battery to it and it engaged/spun, thats what they would do at say autozoen to test if its good or not...but in the car it doesnt turn.
Do you have power going to the S-termial? Do you have power going to main power to the starter?
i am having the same kind of prob i am getting ready to change the ignition switch
Re: (dotcom)
The exact happened to me but I mistakenly disconnected a wire to the starter solenoid. Plugged it up and it was perfect.
yep check the ground from tranny to frame...must be a decent sized wire...
