Starter Problem
Starter Problem
I have had intermittent problems when trying to start car. I turn the key to start and nothing happens. The lights on the dash come on, I hear the ecu click but the starter does not turn. I have to keep turning the key from position II to position III till finally the starter turns. I replaced the starter with a new rebuilt figuring for sure it was the starter. I still have the same problem, what else can I check?
Thanks
Thanks
Re: Starter Problem
If you have a manual transmission, you also should check whether the starter switch at the top of the clutch pedal is faulty.
Automatic transmissions have a related gear position switch in the gear console that should be checked.
Re: Starter Problem
This car is a 5-sp. I looked at the switch at the top of the clutch peddle and it's not sticking, seems to be working ok. I don't know how to test it with a meter? Anybody know how to test it with a meter?
When I turn the key to start the dash lights come on but does not crank, but I noticed that if I hold the key in the start position there is like a 3 second delay then it turns over and starts. Any ideas?
Re: Starter Problem
you have to put your shoulders down on the floor mats and look up at the top of the clutch pedal assembly.
there is a switch on the clutch pedal, unplug it try it, then try it with a piece of wire stuck in both terminals of the switch (jumped/shorted)
but from reading your original post... it sounds like your ignition switch may have an intermittent fault.
