cluster swap problem
so i swapped my stock cluster to a jdm cluster with a tach. and since ive switched it the turn signals, hazards and rpm's dont work. i tried putting the stock one back on and the turn signals and hazards still dont work. does anyone know why this is happening or can help me out ? thanks
Re: cluster swap problem
yeah the bulbs are still good, when i first swapped it everything was working. and then when i tried them out again it wasnt working.
so i went in the fuse box and found a broken fuse on the "backup light" part. i replaced it and turned the blinker to the right, it worked, and once i turned it to the left the fuse blew out. i tried this with 3 fuses and the same thing happened. i think it might be because i do not have the right light bulb in my corner light, could this be the reason why ? or does that not matter? and the bulb is still on it never blew out . thanks in advance
I had the wrong bulbs in my corner lights and kept blowing fuses too, so I bought the right bulbs and new fuses and all was fine. I thought it was a short too but who knows, maybe your problem is as stupidly small as that haha one can only hope..
alright ill go to autozone and buy the right bulbs, and if not then i guess its a short =/. i hope not though ! thanks guy for the info
akcapr
11
02-27-2011 09:55 PM
yeegsr
06-28-2005 10:40 PM
Endless
11-17-2002 09:44 PM
