Crazy idle????? Throttle plate adjustments??
Old Nov 15, 2002 | 09:21 AM
Shft@9GSR's Avatar
Default Crazy idle????? Throttle plate adjustments??
Ok here's the deal. Aftermarket TB. TPS set to .497 at closed throttle. Idle screw all the way closed.
Idle is at about 1100rpms. Small surge to 1400rpms. No CEL.
pull the AIC. Idles drops to a steady 500. Put my hand over TB opening and the car dies. So I can assume that there are no vacuum leaks.
What gives?
What kind of effects occur when the throttle plate isn't exactly closed all the way? Would this cause my problem? Also, should the car die in a normal set up if the idle screw is all the way closed? Just wondering.
Is there a way to tell or adjust the throttle plate to be closed all the way?
Any help would be appreciated. Thanks in advance
Old Nov 15, 2002 | 09:24 AM
Spade's Avatar
Default Re: Crazy idle????? Throttle plate adjustments?? (Shft@9GSR)
Clean the IACV with some carb cleaner and get a new gasket for it.
Old Nov 15, 2002 | 10:41 AM
Mista Bone's Avatar
D Tranny Guru
throttle blade not fully sealed in the opening, adjust the stop screw.
Old Nov 15, 2002 | 10:55 AM
EE_Chris's Avatar
Default Re: Crazy idle????? Throttle plate adjustments?? (Mista Bone)
I thought that the throttle blade shouldn't be 'fully' seated in the bore, as after awhile it would cause a 'rounding out' where it comes into contact, thus creating a bigger air leak....any truth to that?
Old Nov 15, 2002 | 11:21 AM
Shft@9GSR's Avatar
But the question is... when do you know where fully closed is? by adjusting the stop, when will I know where "closed" is? I'm looking for an easy way to know where closed is supposed to be. is there an easy way to figure this?
I will try to adjust the stop screw as best I can.
s13hero
13
Apr 17, 2017 09:37 AM
EVS90
Mar 16, 2014 04:27 PM
raverx3m
Apr 21, 2013 05:07 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
foumer
May 7, 2006 07:37 AM
