Help, brake lights stay on after battery replacement.
New User
Hey guys I'm new to the EF world. I just picked up a 90 HF with a dead battery. After I replaced the battery, I start the car and the brake lights come on without me even touching the brake pedal. Even after shutting the car off, both brake lights and 3rd brake light stays on. Any suggestions?
1 Post
check the switch at the top of the brake pedal, possible stuck, or still being depressed.
in most if not all cars, the car can be completely off w/ ign key out and the brake lights still work.
Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">check the switch at the top of the brake pedal, possible stuck, or still being depressed.
Yeah. There is a small round plastic piece on the brake pedal that pushes on the switch. I've had this plastic piece fall out before. had the same problem with the lights staying on.
Location: I told you to wait in the truck in Texas, United States
Re: (Kalokohan)
There is supposed to be a rubber piece there...
What happens is it rots and crumbles into pieces..
For a temporary fix,I stuck a bolt in the hole or some
tape a coin there..
The dealer should have the part in stock..
tape a coin there..
gsrsuperman
13
07-21-2008 10:20 AM
RanCRX
06-09-2008 07:35 PM
