Question about LSVTEC....
What up..
Im getting ready to order my golden eagle vtec conv..I will be using a 99 b18b block with 00 b16a2 head, my question is what oil pump, water pump, timing belt, and head studs am i suppost to use??
thanks alot
thanks alot
Aren't B16 studs shorter or something? Every keeps giving mixed stories on them
Most people tell you to get GSR studs.
I used GSR studs on my LSVTEC and they were the right length. Get them and be sure.
If you're going to rev high (duh) then get the vtec water pump. You need to use the right timing belt coresponding to your water pump. Vtec pump, gsr belt, ls pump, ls belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">I read to only use the headstuds meant for your head, so b16 head = b16 studs</TD></TR></TABLE>
you read wrong. use gsr/itr studs.
follow the link in my sig for EVERYTHING lsvtec related.
bambam i believe u but are you 100% possitive about using GSR/ITR head studs with my b16 head?? i just wanna make sure because im about to start ordering everything...
thanks
thanks
Dead CIVIC
15
Mar 2, 2008 08:47 AM
ScottEK
Jun 26, 2005 01:58 PM
